LogSplitter No power on stroke or return
   / LogSplitter No power on stroke or return
Engine dying is either pump is not automatically shifting into power displacement (smaller gear set) or you have engine issues (bad gas ect..??)
If the pump doesn't shift down to the high power mode (slower) then your engine is trying to push too many gpm's resulting in engine stall
A flow meter would troubleshoot this condition if it was hyd related.....not sure if a hyd guage would tell ya much other than what the pressure is when it stalls
engine should have enough power to go into pressure relief if the pump is kicking into second stage
Is there anything I can tell by working on the pump? Tearing it down or some kind of troubleshooting?
Would air in the system cause these symptoms? Should I try to bleed the line somewhere on the cylinder?
Again, thanks for the reply and the help.
Can you tell from the pictures that I posted, which is the main relief? Is it the large "bolt" that is next to the handle? Sorry, new to hydraulics and a lot of the terminology. Been looking for some parts diagrams and stuff when I have a chance, but not finding necessarily the specifics I need.
Thanks again.
   / LogSplitter No power on stroke or return #14
If you had air in the system, then your splitter would still push, not stall motor. Air is compressible so it shouldnt stall motor at least in my experience. your ram will act like a shock absorber as soon it pushes wood thru bouncing back dangerously. something looks like the flow is blocked in valve somewhere or valve is not setup correctly.
   / LogSplitter No power on stroke or return #15
Another thought- look at the pump and see if there is an rotational arrow and see if the engine shaft is spinning same direction.
If you have time, I'd take the hoses off and see if there are any restrictions in the hose. They look brandnew, but you never know if there is hose debris left somewhere from being made and since its a homemade unit, I would start downloading manuals for valve, pump and engine and confirm the setup, hose connections, etc.
   / LogSplitter No power on stroke or return #16
could be a bad seal on the inside rod end alowing it to bypass eitherway I have seen it
   / LogSplitter No power on stroke or return #17
I would also check the hoses if one is over crimped it will produce the symptoms you describe
Yes, the main relief is by the handle. Your valve looks similar to this one.
http://www.princehyd.com/Portals/0/products/valves/catalog/ValvesLsRd25.pdf
All parts are available.
Surplus Center - 1 SPOOL 25 GPM LOG SPLITTER VALVE W/AUTO DETENT
$64
OK, I took out the main relief valve and inspected it. Didn't see anything obviously wrong with it. I got the spring out, but wasn't able to get anything else out. The ball or pin inside was loose but I wasn't able to remove it.
I re-assembled everything and started it back up. The results were much better, however, there still wasn't enough pressure to split a piece of red oak (fairly straight grained, short in length, and dried for over a year). I did have an old piece of hickory that split easily, but 2 pieces of red oak were a no no.
Uploaded an updated video. You can hear the improvement, and you can hear the motor pushing against the wood........ but the wood winning. Sorry for the shakiness, hard to hold camera, run splitter and keep wood in place.
Updated Log Splitter.avi - YouTube
Thanks again for all the assistance. It is much appreciated. (Once I get this thing running, my 73 year old father won't have to split his wood with his sledge hammer anymore.........)
   / LogSplitter No power on stroke or return #19
By your picture it looks like the intake hose from tank is flat or kinked. Check of a screen in tank.
I checked the intake hose, and especially during operation and it is not pinched or restricted. Going to try to find a hydraulic pressure gauge and figure out how to install it inline, and see if I can determine if my pump is bad or not (not switching to high pressure/low flow during load).
Thanks for the input.
CATERPILLAR 631G MOTOR SCRAPER (A52706)
CATERPILLAR 631G...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
2003 Pierce Spartan Pumper Fire Truck (A51692)
2003 Pierce...
2020 CATERPILLAR 299D3XE SKID STEER (A52705)
2020 CATERPILLAR...
2020 EAST TEXAS TRAILER STEAMER TRAILER (A53843)
2020 EAST TEXAS...
