Long range wireless router help
   / Long range wireless router help #81
A USB727 is exactly the same modem I have.
I'm using an L-Com parabolic grid antenna (image below)
900 MHz 15 dBi Die-cast Grid Antennas
You need to know where your Verizon antenna is to use this antenna - it's directional. There are other omni-directional antennas you can use (Probably what you have now)
I mounted it outside and use the ultra low-loss coax cable from 3gstore.com
30 foot 9913-Equivalent Ultra-Low-Loss Coaxial Cable (N-male connectors) 952330 [952330] - $49.95 : 3Gstore.com
I went from about -99db to an average of -76db RSS
Just now, I got 1.26 Mb/s down and .70 Mb/s up
http://www.speedtest.net/result/1369635174.png
Here's instructions on how to lock your modem in 3G/EVDO mode
Tip Of The Week #65: Lock Your Verizon Modem to 3G/EVDO Only : EVDOinfo.com
Best of luck to you...
   / Long range wireless router help #82
I work for a railroad and we routinely do long-distance wireless. Look for a good 802.11a 5.8Ghz wireless bridge - they have the best thruput and are less susceptable to interference from other wireless "stuff".
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2003 Big Tex 10PI...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
(2) POLY DRUMS (A52708)
(2) POLY DRUMS...
2019 Grove TMS500-2 40 Ton Hydraulic Truck Crane (A60460)
2019 Grove...
