Long road to home.
   / Long road to home.
Thank you sir. The best part is how much our daughter likes it. All you have to do is suggest going to the farm and you won't hear the end of it!
Is that a mule deer in your photo? It looks like a white spot on the bottom of its neck. Also, did you add color dye to your pond or is that the natural green color?
We did add a bottle of dye last year, was supposed to help keep algae down. I didn't notice any difference and 3 wks later it was back to pond water green. we don't get much algae so I won't bother with the dye again.
   / Long road to home. #14
That is one chubby looking doe.
Was out at the property this past week for a couple days. I had two loads of bank run gravel delivered before I got there, so I got some seat time on the 5530 spreading it out. Here are some pictures. I decided to go with the bank run strictly because of cost. Doing 500' of driveway in crushed limestone is just not in the budget. The gentlemen I get my bank run from provide us with a very good product, it really packs immediately and very stable. There are some over size stones to deal with but at 40% of the cost of crusher run I can deal with them. When it is all done I will top it with 3-4" of the crusher run top dress it up.
I also picked up a 7' landscape rake from Tractor Supply to help grade the bank run. It did well, although I decided to fabricate a hydraulic angle for it. I quickly got tired of climbing off and on the tractor every time it wanted to change it. As soon as I get some pictures of the rake I will post them.
   / Long road to home. #16
Yes, I get tired of getting off the tractor to adjust the angle on my box blade or grading blade. However, I just make do because I don't want to pay for a hydraulic angle adjustment.
Obed
It wasn't that bad cost wise. I got the ram, hoses and fittings at Tractor Supply and a piece of 3/4" x 2 1/2" x 36" steel from Klein Steel all for around 225.00. Then it was just a matter of my time to fabricate it. Was well worth it.
   / Long road to home. #18
Looks like you've got a great dog to supervise the work so I think you'll have a fine place when all is done. :thumbsup:
Hope every step of every project goes better than expected and comes in under budget.
Two more loads of gravel graded, spoils from driveway dig out spread around pond birm to widen it and lessen the slope. Driveway is now 175' off the road. Also managed to bend my landscape rake yesterday, so I spent an hour trying to disassemble and figure out a fix.
Forgot to add, got a ball park estimate on the septic. 9k or 16k depending on whether I have enough slope or not. Well estimate is 2800 for drilling and casing, pump and piping add 1400. Those are way better then I thought they were going to be.
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
(9) ROLLS OF 5' - 10 GAUGE CONCRETE WIRE (A54757)
(9) ROLLS OF 5' -...
2017 BOBCAT T650 SKID STEER (A52707)
2017 BOBCAT T650...
2020 HINO 268 26FT NON CDL BOX TRUCK (A54313)
2020 HINO 268 26FT...
2021 K and K System MB3L S/A Solar Towable Message Board (A55851)
2021 K and K...
