Jerry/MT
Elite Member
- Joined
- Feb 2, 2008
- Messages
- 3,141
- Location
- North Idaho-The Palouse
- Tractor
- New Holland TD95D, Ford 4610 & Kubota M4500
Thank you all for the good advice! Unfortunately, there's no electric in the unit so no trickle charger possible. I figured I'd have to buy a new battery, for sure. That's probably $100 or so I suppose. Otherwise, I will look into what Jerry/MT said re draining water from the injectors (?) though that may be a bit beyond me. Yes, I topped it off at a truck stop so the diesel is probably the good kind and there is a diesel additive to prevent gelling and "improve" the fuel which i put in before i stored it. So thanks everyone!
On the fuel filter canister, there maybe a drain. That's what you should drain before start up. Don't drain the injectors. You'll need to prime the fuel system though and the instructions should be in your owners manual. If you don't have one see your dealer or look on eebay. Pull the battery out and take it home and charge it and reinstall. It ain't rocket science. Replace it only if it won't take a charge.
