Longest power outage?
   / Longest power outage? #81
I'm cycling the Onan 150kW gen-set as I write this Sunday morning.
Every two weeks for 30 minutes under load with a 10 minute cool down.
Block Heater is thermostatically controlled so it is never a totally cold start.
180 gallon capacity with a double containment tank with leak sensors.
   / Longest power outage? #82
Power was out a little over 4 hours at one time last month... within 6 seconds genset was up and transferred..
   / Longest power outage? #83
I'm cycling the Onan 150kW gen-set as I write this Sunday morning. Every two weeks for 30 minutes under load with a 10 minute cool down. Block Heater is thermostatically controlled so it is never a totally cold start. 180 gallon capacity with a double containment tank with leak sensors. Power was out a little over 4 hours at one time last month... within 6 seconds genset was up and transferred..
I'll bite what are you powering that you need a genset that large? I'd imagine that large wouldn't run long on 180 gallons
   / Longest power outage? #84
Don't you need a special license to plug in a block heater in Cali ?
Though..... :rolleyes: I probably shouldn't even joke about that....
Rgds, D.
   / Longest power outage? #85
About how long does the engine run, before auto-shutdown kicks in ?
The entire test runs 30 seconds and the generator runs about 25 seconds.
   / Longest power outage? #87
i changed oil and plugs on my whole house last month. all tested and ready for winter. also did same to 2 portables out in shop. while i was at it, i winterized jet skis, lawn mower and chain saws.
   / Longest power outage? #88
The longest our property has been without power was 11 days during the 1997 Ice Storm. The trusty Honda 5KW generator a friend sold us then breathed its last this summer. I looked at propane but opted for a 7.5 KW PTO generator. Our 250 lb propane tank would be empty after two days of running in a major outage. What then? The tractors (4) carry quite a bit of diesel in their tanks, and there's also the 250 gallons of furnace oil. I bought a 12v transfer pump.
   / Longest power outage? #89
Thanks Mike.
Was just curious..... The Generac a buddy has does something like a 15 minute run for it's exercise cycle. If you don't commonly have power outages, do you ever Manually force yours to run longer to heat up the engine/oil ?
Rgds, D.
   / Longest power outage? #90
A hospital if I remember correctly.
Aaron Z
And.... if my memory serves, ur was pushing for a larger amount of diesel storage..... but he was speaking a dialect not commonly understood by bureacrats, esp. in Cali.....
Common Sense dictates that when the Big One hits out there, you'll be waiting "a while" to get diesel delivered.
Rgds, D.
AT 26in x 11-12in (A52377)
AT 26in x 11-12in...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A54313)
2005 INTERNATIONAL...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
