Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters
Something to look forward to! :thumbsup:
Hi All,
Pretty cool video of our MIGWELD 250P by Kevin Caron. Check it out!
[ame=http://www.youtube.com/watch?v=i2e8Z5AVWLI&feature=context&context=G2daf611UCGXQYbcTJ33YS_J2W7cU4Pu7yv3i3tNh_6E9vzA7oTU0]How to Use a Longevity MIG Welder With Pulse Control - Kevin Caron - YouTube[/ame]
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #173
Thinking of making a purchase from this brand, 200i model or any others please pm me if you can for any comments.
Hi Jamming,
Thank you for your interest. I will PM you some details, but I would like to possibly have you speak with one of our certified welders about the model of your interest and also with one of our sales guys to make sure that our equipment meets your needs!
Thank you for the opportunity. We are open 6 days a week and pretty much from 6am to 9PM on Tuesday, Wednesday, and Thursday. (Pacific Time)
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #175
Hi Jamming,
Thank you for your response, and for answering the phone. I have already spoke to Simon and he was very helpful thank you !
You are welcome! Let us know if we can help further!
Hi Tractor Members!
LONGEVITY is giving away $1800 toward any equipment on the LONGEVITY Website.
Click on the banner for details!
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #179
Finally got home and unpacked my stickweld 250. Problem is the manual is full of holes and quite incomplete. The unit is supposedly a single and/or 3 phase capable unit but the wires in the feed cable are color coded otherwise. Three phase is red, black, blue with white common( if supplied) and green ground. This cable has red black white and green, which is single phase 240volt coding with common. It is either not three phase capable or wire color code is wrong and white is not common but is hot and the unit has no common only ground. Manual as supplied does not address and online manual for the 250 must be way out of date as it looks like it is European in color code and is not useful. Do not want to burn unit up by treating white as hot but the test they did prior to shipping they stripped black white green and not the red making me think they did not use the red wire thus it maybe the third phase which was not tested or something else. Anyway I am not willing to plug it in until I get verification. Tried to call Simon and went to voicemail. Any suggestions based on firsthand knowledge as an opinion might fry the unit. Deereman you just got one how did you wire the plug?
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #180
hi Trovenn Forestry,
your assumption is correct,
RED = 3rd leg for 3 phase
Green = Ground / Neutral (Ground / Neutral are bonded at breaker panel usually)
White = Hot
Black = Hot
In this video Kevin covers wiring at the beginning.
I to found the manual needing improvement. Forcing us to search other sources to obtain information needed.
The Stickweld 140 manual helps a little. StickWeld_140_Manual
Also a suggestion, make sure the Power Wiring is a large enough gauge (from breaker to machine), 10 gauge minimum for very short runs. I convinced myself that most all issues I read about home owner welders is that the wiring or extension cord is to small. Not enough copper to carry the current and putting stress on the machine causing failure. Lots of electrical equipment is burnt out because of it. (ex: a friend sold new refrigerators, he would go to customer for replacement and almost always found the common lamp extension cord for power. New fridge with properly sized cord = problem solved)
Good Luck
2000 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
2000 Mack CH613...
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A51694)
2005 Northwood...
(4) Semi Tires (A50121)
(4) Semi Tires...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2020 Case TV450B Skidloader (RIDE AND DRIVE) (A50774)
2020 Case TV450B...
