Look What I Found
   / Look What I Found #11
Dang. I wish someone would leave something like that here! /forums/images/graemlins/shocked.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif
   / Look What I Found #12
Dang Billy,
How did my tractor roll all the way to your place. /forums/images/graemlins/wink.gif I will be there in a day or two to pick it up! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Looks like someone already claimed it. (RedRocker)
   / Look What I Found
I pulled the old tractor to the house yesterday. After further inspection I'm not sure it was even driven to where I found it. The radiator is about half full of coal black thick oily gunk. I can put it in gear and still push it by hand, the same as I can in neutral. I'm thinking this will probably be a parts tractor.
   / Look What I Found #14
When Jerry said about it rolling away I was going to say he should have left it in gear, But from what your telling us it would have made no difference /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Sparkle plugs still in it?? /forums/images/graemlins/blush.gif
   / Look What I Found #15
</font><font color="blue" class="small">( I pulled the old tractor to the house yesterday. After further inspection I'm not sure it was even driven to where I found it. The radiator is about half full of coal black thick oily gunk. I can put it in gear and still push it by hand, the same as I can in neutral. I'm thinking this will probably be a parts tractor. )</font>
It sounds to me like a cracked block or head with the radiator full of oil. Since the block can be sleeved, I think you might be surprised at how these tractors can be restored if you want. The only problem is you can quickly spend $3,000 and end up with a great looking $2,500 tractor. A parts tractor might be the best idea. You might make a bunch off of it that way. /forums/images/graemlins/cool.gif
   / Look What I Found #16
"I found this old Ford in the corner of my pasture Sunday."
That's a good way to get a tractor home.. w/out letting the Mrs. know you bought it. /forums/images/graemlins/grin.gif
   / Look What I Found #17
So are you thinking someone just dumped it there to get rid of it, rather than stole it? If so, I'd suspect someone's wife getting rid of her hubby's project! /forums/images/graemlins/tongue.gif
   / Look What I Found #18
"It followed me home... can I keep it???" /forums/images/graemlins/grin.gif
People just drop off unwanted dogs and empty beer cans around here. If I could only convince the better half that I found "all those implements that keep showing up" along the road!
   / Look What I Found #19
You should have the sheriff run the v.i.n. or serial numbers (if it has one) through NCIC. That way, even if were stolen from outside his jurisdiction, even another state (your sheriff probably just checked the local reports), it would show up. Anytime a vehicle or piece of property is reported stolen to a proper law enforcement agency, the identifying number should be entered in NCIC.
It's sort of the national database we use in law enforcement.
Most, if not all, states share their records with it.
If it's clear through that, then you're probably home free.
At least this way you don't end up putting money into it, then finding out it was stolen from somewhere.
It's probably not, but better safe than sorry.
good luck,
anthony
   / Look What I Found #20
anthonyk, is right. Your local law enforcement should run it through NCIC (National Crime Information Center) if it has any numbers to run? Hope nothin turns up and it's yours /forums/images/graemlins/grin.gif
David
Frontier WR1008 - 8 Wheel Pull Type Hay Rake (A55218)
Frontier WR1008 -...
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
UNUSED LANDHONOR TP2-13-08D HYD TREE PULLER (A54757)
UNUSED LANDHONOR...
2024 VOLVO VNL760 SLEEPER TRUCK (A54607)
2024 VOLVO VNL760...
2017 Freightliner M2 106 TMA Attenuator Truck (A52377)
2017 Freightliner...
Splash 10ft 2,100 Gallon Water Tank Truck Body (A52377)
Splash 10ft 2,100...
