JohninCT
Platinum Member
Right now I have this on the current blade. I also have offset. I get to unbolt the blade from it's attachment points, pull the blade over and then re-bolt it. A quick offset is just nicer.
So I have to some small degree, tilt and offset. I'd just like these as easier features.
Larry
It appears that you have a quality Lanpride blade that has all the features that you want. Might I suggest that all you need to do is make some mods to your existing blade to make the features easier to use. Looking at the LP blade manual...
1. you could add another tilt plate with more holes to get more tilt angle on the blade.
2. you could add a slotted channel to the top back of your blade so that instead of removing bolts and moving blade to offset all you would need to do is loosen the bolts and slide the blade over and retighten. Replace the nuts on these bolts with knobs and you could loosen and tighten without tools
