Originally Posted by SamshineAh, but you have to remember that we are dealing with 2 parallel strings each with 2 diodes that are in series with the arc between them. (The two parallel strings just happen to be connected to separate transformer legs.)
If the forward diodes are in series then the reverse-biased diodes are also in series. Take a look at the attached schematic for a better view.
Colored lines and arrows indicate current flow during each transformer phase. (I.e. Blue lines, left side of transformer is - right is +. Red line, Left is + Right is -.)
You can see that at any point in time the diodes in the green box will always be in series and the diodes in the turquoise box will also always be in series.
Transit after looking at the drawing. The diode hook up looks good.
The only problem i see is the transformer hook up.
This transformer has 4 wires coming from it.
Two wires hook up to the dc pos. welding lead.
Two wires hooks up to the number C heat sink. Also another hook up hooks from the same number C heat sink and runs to the dc neg. welding lead.
Like i mentioned earlier this welder has three transformers. I was told one was a secondary transformer. These other two tranformers are the ones at the top. The slider bar runs up and down between the transformers to change the amp. There is two wires running from one of these transformers and hooking up to the dc neg welding lead as well. Also there is just one wire running from one of the transformers up top and hooks up to number A heat sink.
Thanks for all your help. samshine
