bluechip
Veteran Member
Perhaps Buck is referring to EPA's Tier II requirements which went into effect Jan 1.
I checked with EPA in January and was assured the TPEM (Transition program for equipment manufacturers) will continue to allow 25-<50HP imports through calender year 2005, as the 7 year allowance started in CY 1999. Smaller (<25HP) engines have another year after that.
The problem is that each importer can only exempt one engine manufacturer for each HP class and then is limited to 200 non compliant engines per year total. For example you couldn't import both the 28HP Jinma and the 35HP because the engines come from different factories (although you could bring in the 4 cylinder 35HP because it is made by the same company that makes the Y385 in the JM284). This is why some importers continue to bring in 1998 and 1999 engines.
Im a little in the dark about over 50HP, since by my reading, they were already under Tier I when the TPEM program was implemented, so we have avoided importing them, although they are listed in the TPEM program, as I recall, till the end of this year.
If any of this has changed, I'd sure like to know about it right away!
