Looking for source for plated hydraulic tubing - if possible.
   / Looking for source for plated hydraulic tubing - if possible. #1
jim_wilson
Veteran Member
Northeast MA
Kubota B3200 w/ BH77 & 12", 18" & 24" buckets, Kubota B50 SSQA w/ 54" & 60" buckets, LandPride FDR1660, Artillian Fork frame, Extreme 3pt rake, Concrete Mixer, MyTractorTools grapple adapter
I'm looking to add some hydraulics to my tractor, and I want to run hard lines for at least some of it. I've picked a couple of good benders (Diacro and Baileigh) - and I've got a quality Parker flare tool on it's way. Also stopped at the local Parker Store today and picked up a length of 3/8" (unplated) hard line and some fittings.
But what I'd really like to find - if it's even possible - is pre-plated hard line in 3/8".
I've found a source for the stuff in metric sizes ( http://www.parker.com/literature/Tube Fittings Division/MSTwall.pdf ) , but I can't seem to find a source for the stuff in inch sizes.
Paint the bare material with "Instant cold Galvanized" spray after fabrication, then top coat to color.
http://www.crcindustries.com/ei/product_detail.aspx?id=18412
I've actually used that spray galvanizing quite a bit. Mostly the Rust-Oleum product, but I think I've tried the CRC product before too.
I'm thinking of potentially manufacturing a product - which is part of the reason why I'd like to find a pre treated tube. Painting gets to be a pain - and it's probably not going to stand up as well in the long run as a plated tube will
   / Looking for source for plated hydraulic tubing - if possible. #4
Agree! For commercial product, a zinc or epoxy finished tube would be best.
   / Looking for source for plated hydraulic tubing - if possible. #5
How about stainless steel? More expensive though.
   / Looking for source for plated hydraulic tubing - if possible. #6
Actually see.see.onlinemetals.com SS tubing is quite reasonable. I just don't which thickness you should order to have safety, but they would know.
   / Looking for source for plated hydraulic tubing - if possible. #7
Check out McMaster Carr. I see they have Bundyweld hydraulic tube in that size.
   / Looking for source for plated hydraulic tubing - if possible. #8
McMaster is probably best. But I checked on that onlinemetals website and e9r stainless in 3/8 tubing has a burst rating at 20,000 psi and a working psi of 5000 at 049 wall thickness...
   / Looking for source for plated hydraulic tubing - if possible. #9
I checked with my HYD shop for you and they never heard of it and could not find it in a catalog except for automotive brake lines (lot lower working pressure). They also recommended stainless. 316 grade is shiny like chrome.
Ron
   / Looking for source for plated hydraulic tubing - if possible. #10
Seems like I heard years ago that plated tubing has a problem with flaking when bending or flaring. May have to plate it after processing?
45028 (A48082)
45028 (A48082)
Hardi Navigator NP1100 Pull Type Sprayer (A49339)
Hardi Navigator...
Blue Bird School Bus (A46683)
Blue Bird School...
2013 MACK CHU 613 PINNACLE (A48992)
2013 MACK CHU 613...
2017 HINO 258A (A48992)
2017 HINO 258A...
2017 Bobcat E85 Midi Excavator (A46683)
2017 Bobcat E85...
