Looking for source for plated hydraulic tubing - if possible.
   / Looking for source for plated hydraulic tubing - if possible. #1
jim_wilson
Northeast MA
Kubota B3200 w/ BH77 & 12", 18" & 24" buckets, Kubota B50 SSQA w/ 54" & 60" buckets, LandPride FDR1660, Artillian Fork frame, Extreme 3pt rake, Concrete Mixer, MyTractorTools grapple adapter
I'm looking to add some hydraulics to my tractor, and I want to run hard lines for at least some of it. I've picked a couple of good benders (Diacro and Baileigh) - and I've got a quality Parker flare tool on it's way. Also stopped at the local Parker Store today and picked up a length of 3/8" (unplated) hard line and some fittings.
But what I'd really like to find - if it's even possible - is pre-plated hard line in 3/8".
I've found a source for the stuff in metric sizes ( http://www.parker.com/literature/Tube Fittings Division/MSTwall.pdf ) , but I can't seem to find a source for the stuff in inch sizes.
Paint the bare material with "Instant cold Galvanized" spray after fabrication, then top coat to color.
http://www.crcindustries.com/ei/product_detail.aspx?id=18412
I've actually used that spray galvanizing quite a bit. Mostly the Rust-Oleum product, but I think I've tried the CRC product before too.
I'm thinking of potentially manufacturing a product - which is part of the reason why I'd like to find a pre treated tube. Painting gets to be a pain - and it's probably not going to stand up as well in the long run as a plated tube will
   / Looking for source for plated hydraulic tubing - if possible. #4
Agree! For commercial product, a zinc or epoxy finished tube would be best.
   / Looking for source for plated hydraulic tubing - if possible. #5
How about stainless steel? More expensive though.
   / Looking for source for plated hydraulic tubing - if possible. #6
Actually see.see.onlinemetals.com SS tubing is quite reasonable. I just don't which thickness you should order to have safety, but they would know.
   / Looking for source for plated hydraulic tubing - if possible. #7
Check out McMaster Carr. I see they have Bundyweld hydraulic tube in that size.
   / Looking for source for plated hydraulic tubing - if possible. #8
McMaster is probably best. But I checked on that onlinemetals website and e9r stainless in 3/8 tubing has a burst rating at 20,000 psi and a working psi of 5000 at 049 wall thickness...
   / Looking for source for plated hydraulic tubing - if possible. #9
I checked with my HYD shop for you and they never heard of it and could not find it in a catalog except for automotive brake lines (lot lower working pressure). They also recommended stainless. 316 grade is shiny like chrome.
Ron
   / Looking for source for plated hydraulic tubing - if possible. #10
Seems like I heard years ago that plated tubing has a problem with flaking when bending or flaring. May have to plate it after processing?
40' 1 Trip Shipping Container (A59814)
40' 1 Trip...
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
Wolverine Quick Attach Hydro. Adjust Forks (A59814)
Wolverine Quick...
500BBL WHEELED...
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
2006 Chevrolet Express 3500 Cargo Van (A59230)
2006 Chevrolet...
