Looking for USED F-350 - Which year/engine/model is best?
   / Looking for USED F-350 - Which year/engine/model is best? #151
Your experience has been the same as mine. We have tons of 6.0L in my town and for the most part have a good reputation but there will always be the non believers.
If I were buying a used one today I would spring for ARP studs and a EGR delete from the get go then drive it like I stole it with 5K oil changes.
Mine were always happy with 15,000# to 25,000# behind them.
Chris
i just went to 5k intervals and valvolene permium blue full syn 5w40 oil in my 6.0.. finally convinced the boss it was worth it.
I've already been using that oil in both my 7.3's since i got them.
all mine pull trailers weekly. that 6.0 has made multiple cross country trips pulling a trailer with a tracor on it, running more or less full time there and back.. only being shut down for fuel, doing red eye trips. one trip to texas, we stopped for fuel every 4-5 hours, truck got to rest the 5-15 minutes we were at the truck stops each time.. one of us slept while the other drove.. truck seemed to enjoy it.. :)
   / Looking for USED F-350 - Which year/engine/model is best? #152
I have been pulling and plowing with a 2002 F350 dually and the 7.3 with 4.11 gears, It has a full Banks kit and exhaust brake with 135,000 miles....I have been happy with it and worked it hard pulling a 14 K GVW gooseneck with 12-14 K on it. I am overweight on the trailer axles and am looking to upsize the trailer to a 20K GVW gooseneck.
1. How much can I legally pull with this F350 GVW 13,500?
2. How much can I safley pull with this F350 GVW 13,500?
What is the load capacity difference between a F-350 Dual and Single rear wheel?
Also, do the 4x4 unit's have lower load capacity or the same as 2wd?
Thanks,
David
   / Looking for USED F-350 - Which year/engine/model is best? #154
Look in your manual for your truck and it will list the max tow rating. I think it will be in the 18,000# ball park.
As far as safely its a matter of opinion. I pull a 25,000# BP boat with my 06 SRW 4x4 F-350 Power Stroke and I used to pull a 25+5 GN with my 1999 SRW 4x4 F-350. Its all about the equipment, driver, terrain, ect.
Chris
   / Looking for USED F-350 - Which year/engine/model is best? #155
Thanks,
David
There is about 2,000# difference in the GVWR if you order both with the max setups but of course the Dually is about 400# heavier so real world its 1500 to 1600#.
The 4x4 has a slightly lower capacity because that weight comes strait off the GVWR and the GCWR, so also lower tow rating by about 400# also but I would not care. No way I am buying a 2 wheel drive truck.
For that matter back when Ford had the V10 it actually had a slightly higher tow rating and payload versus the Power Stroke Diesel due to weight. The diesel is about 500# heavier.
Chris
Chris
Thanks Chris, excellemnt info!
David
   / Looking for USED F-350 - Which year/engine/model is best? #157
Legal depends on what state you are in when/if you get checked.
My 2002 F350 dually 7.3L 4x4 w/auto 4.10 gears (not 4.11) has the optional 11,500lb GVWR package, (compared to a standard 11,200lb) and is rated in the manual for 20,000 lbs GCWR. On all the web sites max trailer tow capacity is listed as 12,500 conventional, 12,700lbs fifth-wheel/gooseneck.
I believe I could safely tow far more than the 12,700 lbs.
   / Looking for USED F-350 - Which year/engine/model is best? #158
Its amazing how much trucks have changed in the last few years. My F350 SRW has 11,500# GVWR and about a 16,000# tow rating. The Duallys now are 13,500 and higher with nearly a 24,000# tow rating.
Chris
   / Looking for USED F-350 - Which year/engine/model is best? #159
David,
Sorry it took me so long to respond to this thread. I've had both an '01 with the 7.3L powerstroke and the '06 with the 6.0L powerstroke. Both were 4x4 Crew cab Duallies with the 6-spd manual trans and 4.10 gears. The cam sensor failed on the '01 and the turbo went on the '06 (both were covered under warranty). Other than that, I did not have a lick of trouble out of either. I exceeded 120,000 on each before letting them go. And, I only sold them due to pending deployments. Otherwise, I would still have one or the other.
I prefer the duallie, but a SRW crew cab will handle your tractor and horses. Anything heavier...well, you have seen what I have in the backyard to take care of any heavy hauling. They are available when needed.
What can you legally tow? Not sure about a SRW, but I have gone across the scales there in Lorton at 29.5k with the '01 and 29.4k with the '06 (got the pictures to prove it too:D) . I got the green light both times. Both trucks pulled those loads up I-95 with the cruise set at 65. I might have had to drop back to 5th once or twice. So, I reckon you are good to at least 17-18k. Just watch your speed and increase your stopping distance.
Check all the hoses coming off the turbo and that are part of the intercooler. I didn't have any problems with the 7.3 but I kept blowing the hoses off the 6.0 with minimal boost. If you see any traces of oil (fresh or otherwise) on any of the hoses replace them. No damage is done when they blow. But, it sounds as if a rocket is shot off underneath the hood and all power is lost. It took me a while to figure that out and it was frustrating as all get out.
Bottomline, I'd recommend an '01 and earlier, or an '06 and newer. Looking forward to sitting under the shade tree and spending the rest of the afternoon checking it out :thumbsup:
Hawk
Hawk
Amen to that sir!
Likewise.
I'm off to get at least 30 bales of hay....
O & O.
David
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2016 Ford Taurus AWD Sedan (A53424)
2016 Ford Taurus...
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
2013 Audi A6 AWD Sedan (A53424)
2013 Audi A6 AWD...
