looking to buy a stihl saw 14-16" 10% off at dealer tomorrow, recommendations?
   / looking to buy a stihl saw 14-16" 10% off at dealer tomorrow, recommendations? #41
Re: looking to buy a stihl saw 14-16" 10% off at dealer tomorrow, recommendations?
I been running the MS 290 (Farm Boss) and it's been a great saw with muffler mod. The new replacement is the 291 which the EPA compliant variant.
   / looking to buy a stihl saw 14-16" 10% off at dealer tomorrow, recommendations? #42
I have the 290. Nice saw. Looking for a pole saw now.
   / looking to buy a stihl saw 14-16" 10% off at dealer tomorrow, recommendations? #43
see you have a PHD. a doctorate? or post hole digger? the ladder may be more useful :) be sure to get the extendable type pole saw.
   / looking to buy a stihl saw 14-16" 10% off at dealer tomorrow, recommendations? #44
I'm almost smart enough for the manual post hole digger. My brother tried the chain saw up a ladder trick many yrs ago, he was holding the ladder for the duffus up the ladder with the saw. He got a big cut on the arm when duffus dropped the running saw.
Good luck and let us know what you choose.
I had basically decided on a 250; but read on....
Sorry, I did not write sooner, combination of being busy, and not knowing that there were more posts...
Prior to the actual dinner part of thanksgiving I was researching saws on the laptop, and one of the guests (non-family) had asked what I was looking up. I stated chainsaws for a sale tomorrow. long story short... I ending up being offered his saw if I would use it to cut down a really bug shrub/small tree and a larger dead oak. It ended up being a barely used 11year old 250! now comes that bad side of the deal. I 'learned' (on sunday) I was also 'expected' to remove the root ball for the smaller tree (due to location hand tools only), and Although I was able to get the saw running without much issue, the oiler is not working. A small part of me wished I had just said no, and bought the new saw.
I have not had time to really work on the oiling issue. I looks like the bar is clean, and I did see a very small trickle of oil (running engine with bar off) but (even after manually lubing chain) chain could not be drier after making just a few cuts (3). So if anyone has any suggestions I am open to it, but it may be a little while before I actually get time to work on it.
I hope everyone had a wonderful thanksgiving, and that no one ate too much!
   / looking to buy a stihl saw 14-16" 10% off at dealer tomorrow, recommendations? #46
have you checked that the oil hole or port in the bar itself is not clogged? you probably already know that there's one on either side of the bar so you can reverse it to equalize wear...good luck w/the root ball, a big job. my take would be that if the saw chain lube does not work, then respectfully return the saw, leave the root ball, and buy a new saw as you had intended.
   / looking to buy a stihl saw 14-16" 10% off at dealer tomorrow, recommendations? #47
Sounds like a good deal. That's a nice saw. Don't forget your sawzall for removing the root ball.
   / looking to buy a stihl saw 14-16" 10% off at dealer tomorrow, recommendations? #48
Sorry I missed this thread. My wife and I have become chainsaw addicts. Who would have ever thought it especially about her. One day while using my faithful Echo 550 that I have had since late 70s my wife said "I would like to try using a chain saw so I could help with the clearing." So I thought , no way with her weak wrists and hands, but I didn't want to just blow her off on that so I shopped for a light weight chainsaw that would actually function as a real chain saw. Wound up with a Stihl ms192c. WOW, than thing was one slick little saw. For limbing, brush, and even firewood I could do so much with it because of the light weight. And to beat all I got my un mechanically inclined wife trained to the point that she could start it on her own, and do some serious tree trimming and felling. She loves it. After I saw that she was taking serious exception to me using that saw when ever she was wanting to use it, I was back to the Echo which weighs about 17 lbs. I said I have to have something better, so I got to looking at something stronger than the ms 192C but only a pound or two heavier and I came upon the MS 241.
I can do nothing but rave about that saw. I can whip it around like a youngster, and it has great power band. It never gives a hint that it is not going to start. Just pull the rope and there it is in a perfect idle from a cold start or after a grueling session cutting a stump at the ground. Let off the trigger and she just idles. And when it is pulling it seems to settle in to the pull different. I can't exactly explain it but it just hunkers down into a smooth pull and doesn't fall off on the torque like none commputer saws.
On top of that it sounds like a BMW a deep growl rather than the banshi scream of the MS 192C or my echo. The lighter weight means more than I could have imagined. A pound or even a few ounces of weight difference can make a world of difference in how much you can do in a given time period. The pro saws have a higher power to weight ratio and that is the money difference. It is hard to be sold on the money difference until you have actually used a light weight pro saw.
My son originally was telling me that the pro saws are just a waste of money but after using our two he has changed his tune. He still cannot believe I actually got my wife to the point of actually getting real work done with a chain saw all on her own. I credit the lovely manners of the MS 192c for that.
My son has several Stihl chain saws and is a kind of Stihl fan boy but when he used my wife's MS 192c he wanted one so we sold him ours and we then bought a ms 193c, the newer replacement. It is also great except it is a little soft on the trigger when want to do light cutting and trimming where you are always letting off and back on. It somewhat feels like it is smothering but otherwise it cuts as good or better than the ms 192c. Then when I get the MS 241C my son tried it and now he says these two saws are what he wants in his stable after years of using the bigger saws.
The MS 241 is pricy but I doubt seriously you would regret it if you actually used one much. A story I thought ought to be told.
   / looking to buy a stihl saw 14-16" 10% off at dealer tomorrow, recommendations? #49
...And to beat all I got my un mechanically inclined wife trained to the point that she could start it on her own, and do some serious tree trimming and felling. She loves it....
No surprise to me. I bought a MS192C for my wife and she has become addicted to using it whenever she can find an excuse- which is pretty much every day she works outside. I have an MS361 and an MS250, but love that 192 whenever she is not using it.
   / looking to buy a stihl saw 14-16" 10% off at dealer tomorrow, recommendations? #50
2017 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
2001 Freightliner FL80 E-One Pumper Fire Truck (A52377)
2001 Freightliner...
2013 Chevrolet Traverse (A53424)
2013 Chevrolet...
UNUSED 70PCS Grey Metal Roof Panels (A53117)
UNUSED 70PCS Grey...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2011 CHEVROLET EXPRESS SERVICE VAN (A51406)
2011 CHEVROLET...
