smince
So, given that these abilities are beyond my current skill set, if there aren't guys locally who can perform the repairs on these machines then these issues need to largely be resolved by the maker. If the lower price requires an understanding that more issues will need to be addressed by the owner, the lack of a close repair facility probably means I probably should buy from a local dealer.
Seems like you already answered your own question, which I think Rich was just trying to help you see? It's too bad you took that so personal even after he explicitly stated "this is not a criticism of you at all". Most all of the people who post on here, including Rich, are extremely helpful.
Any powerful machine with moving parts and hydraulics will eventually need repair or replacement parts, it's just the nature of the beast. Repairs usually go beyond the skills and tools needed for draining fluids, replacing filters and changing tires. You seem to mention hydraulics almost exclusively but there are lots of other, more involved mechanical things that can go wrong with a tractor. Clutches wear and need adjustment (or replacement), shafts break, splines strip, seals start leaking, engine valves need adjusting, etc, etc.
Your local big name dealers will probably not work on a Chinese tractor unless you have sorted that out ahead of time (ask them), or you have located a local tractor mechanic that will do the work for you. Based on what you've said here, it honestly seems like you will be happier spending the extra money on something from a local dealer. When, not if, your tractor breaks down it will be no good to you (no matter how much you spend on it) if you can't get it repaired in a timely and cost-efficient fashion.
Best of luck in your search, and Merry Christmas!
