Looking to increase ZTR speed
   / Looking to increase ZTR speed #1
Husqvarna Guy
Middletown, Ohio
Husqvarna ZTR
Is it possible to increase the speed of my Husqvarna RZ5424! I was a bit spikes in using a Kubota commercial grade for a few weeks and had to return it. I recently bought the Husq and it's just slow. Is there a way to increase the speed of my ZTR?
Thanks
   / Looking to increase ZTR speed #2
Larger hyd pumps with more GPM, but will need more HP
Larger diameter tires, but will decrease the torque
Your speed is determined by the amount of HP available, pump size, motor size, tire size.
If you change just one, you have to adjust another.
   / Looking to increase ZTR speed #3
To change the speed of you ZTR, just get a different machine. The engines, hydraulic motors, pumps and tires are designed as a single unit and not much you can do to change it without boosting up everything on the machine which would be mucho dinero even if it could be done.
Want commercial speed from your mower, get a commercial mower or else just be satisfied with what you have.
   / Looking to increase ZTR speed #4
Just picked up a Husky MZ6128. (w/ZT 3100s) It's sold as a residential mower but ... well its ground speed is a bit fast when cutting if the steering bars are anywhere near fully forward. I suspect it's sorta like having a 'high' range on a HST tractor and fine for traveling vs working. Of course, there are adjustable stops to adjust how far forward the handles can go on many ZTRs, or to balance WFO side to side.
I've tweaked the stops about as far as they can go tying to prevent going too fast when mowing, and still have to moderate how far I push 'em. Reason is obvious, isn't it? Skipping and leaving stripes when revved to get tip speed up there. :eek: With ~2 hrs on the meter (shows only when blades engaged, btw) I'm getting a feel for it but the ride seems rougher than with the much slower CC RZT50. :(
   / Looking to increase ZTR speed #5
Is it possible to increase the speed of my Mazda Miata? I was a bit spoiled in using a Z51 Corvette for a few weeks and had to return it. I recently bought the Miata and it's just slow. Is there a way to increase the speed of my Miata?
Thanks
Sorry about the parody, Husq guy but the above is essentially what you are asking. Your ZTR is what it is and if it no longer makes you happy, then trade it in on a new Kubota or some other brand that offers higher ground speed. As often said, you got what you paid for.
   / Looking to increase ZTR speed #6
Thanks
Depends on how it is made. If chain final drive you can possibly change the size of the drive gear or driven gear.
   / Looking to increase ZTR speed #7
Even though my Fast-Trac Dixie Chopper will run about 13 MPH, you can not really get a decent cut at that speed.
I run it fast when I am finished cutting.
Husqvarna Guy
You probably should have tested about 6 or 7 ZTRs to see which one fits your purpose.
2025 GREAT DANE FLP-0024-00053 53FT SPREAD AXLE FLATBED (A54607)
2025 GREAT DANE...
Test Button (A47477)
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2018 FREIGHTLINER...
2018 JLG 2632ES 26ft Electric Scissor Lift (A55787)
2018 JLG 2632ES...
PALLET OF SCAFFOLDING (APPROX. 7 PC) (A52706)
PALLET OF...
2011 PETERBILT 384 TANDEM AXLE TANKER TRUCK AND TANKER TRAILERS (A54607)
2011 PETERBILT 384...
