Looking to purchase a MF, which one is enough?
   / Looking to purchase a MF, which one is enough?
Kioti is a very high quality tractor, I think you'll find it to be held in high regard. It's going to be a stronger/heavier tractor than any comparable John Deere/Kubota compact and it will do it with a lower price.
Thanks, for your input. 1.5 Hours for dealers is pretty much standard, but this Is also true for Costco and other bigger store. So this is not really a issue for us. Granted 1.5 hours in the wrong direction might be.
My residential uses are not mission-critical. There is no crop to lose if the tractor takes a dump on me. So, my shopping led me to choose what I believe was the best machine that fits my needs. I bypassed local JD and Kubota dealers for what I felt were justifiable reasons. And although I don't have a local Massey dealer, there is reasonable availability of parts and service if needed. You can get many parts delivered overnight if you really, really need to. And in my area there are lots of people who work on tractors-- outside of dealer support. It's a subjective choice about how much weight to assign to having a local dealer.
I do hear you on this. We are also only a Private Household and its not the end of the world if we would have to wait a day longer for a part. Buy having the dealer there for support or on you side dealing with the manufacture can sometimes be a Lifesaver as well. So no we don't need need it right away, but when someone is shaking those clouds and we got 20" of fresh powder I want, want it right away. :)
Minor point to some and major point to others, but I'm tall and when I read a reference like this, it sounds like you may be attempting to straddle the entire pedal on top with your heel and toe and use a rocking motion at ankle joint for operation. If so, try the pedal using it's offset so only heel or toe is on pedal at any one time. Then it becomes pretty effortless.
I tried to use only my Toes or heel, but with it being right under the seat, its just a weird angle. Sure You could increase the Seat Height, maybe set it more back, but since we are looking new I think we do have options out there that just fit.
An excellent topic to discus. The old saying there's no replacement for displacement really comes into it's own in your example here.
The reason I bring this up is when I was tractor shopping I talked to a guy that ran a small business fixing and building driveways and private roads that were often gravel and usually long (several hundred yard hilly driveways and mile long private roads are common here), he had a 3560 when he started and it didn't take him long to start running out of grunt. He promptly stepped up to the 4060 and was good to go from there on out. His advice to me was this, if you are pulling, pushing, moving heavy things up hills, slopes, or long grades you'll need lots of torque. And the extra cylinder will allow you to do the same job with less rpms, less fuel, and in less time. I headed his advise and haven't regretted it. Nalle may have no need for that much power or torque, just thought it was worth mentioning.
I agree with you 100%. The Germans Have a saying: "Hubraum ist durch nichts zu ersetzten." translated to Cubic Inches can't be replaced with anything.
At some point the wallet has to disagree a bit and also our Land, since to big will be a problem.
Have you gone to Tractorhouse.com and done a search on tractors in your area. I think that for your needs don't go below 2500 - 3000lb or less than 25hp - 35hp. For your lane being that long you will want enough weight to put at least a six foot blade on.
Many good tractors out there. Lots of MF fans on here and I am one of them. Also like Kubota and several others. Being a big guy I hear ya.. not everyone understands when you go to shop for something the first thing I do is climb on it/in it. I have basically told saleman not to bother talking about it until I climb on it/in it to see if I fit. If you are not at least 6'4" you may not understand. They don't build things to fit usins.. They have little Japanese engineers climbing in and saying feels great to me. I fit in European cars because those engineers are big : )
Thanks, yes been on Tractorhouse.com. Great for references, but not much on there in the NW. For Size the "larger" Sub-Compacts would work, but very tight. The Compact Size works in most cases and then those in-between is try it on and out. Like you said let the Salesman while I check if it will work for me.
Most things are build for "normal" height people, and the short and tall have to make it work. Positive top shelf seldom a problem, negative hitting the head on .............
All I can say is I liked my little 1710. But now, with the bigger tractor, it's amazing how much more can be done with less wear and tear on the machine and me. I'm happy I stepped up to the T454. It's like night and day and I've only had it 36 hours. Pallet forks arrive tomorrow and I can't wait to see what happens when I put a little weight on the front...more than the little tractor could begin to handle. If you have the weight and power you don't have to use it. If you don't have the weight and power you can't use it.
I need to get some tires filled...
Limiting Factor is the wallet and also Tractor size on the property. So we have to find the Happy middle.
Thanks for everyones input, thoughts and ideas. We have learned a lot and are weighing the options, hopefully soon we will have a ......... Tractor.
   / Looking to purchase a MF, which one is enough? #52
Hi,
I own a 2009 1529 I now have 279 hours it has a loader and back hoe, I also have a GC1701 with loader only. In addition I have an older Mitsubishi MT372D I looked at Green paint, (also powered with same engine and assembled with same systems as MF), Blue paint, both orange paints and some others. I bought both of my MF direct from AGCO and must say I have used them both heavily on our farm. My 1981 Mitsubishi is just to small to manage everything I do. I also own an older Kubota which is a lawn ornament.....
Both MF have beet juice the tires the 1701 is hydrostatic the 1529 shuttle shift they both handle everything I throw at them although removing the backhoe from the 1529 is a 2-3 hour job.
Check the AGCO Finance page for Repos.... You can save a TON of money.
Thanks for the tip. You have a link? I am only find to Big of Tractors right now or looking in the wrong spot.
   / Looking to purchase a MF, which one is enough? #54
Are the current MF compacts and sub-compacts build by ISEKI? I have a Ford 1620 built by this firm in 1992. Still a valuable, reliable compact tractor.
As far as I understand it, yes they are made by ISEKI.
   / Looking to purchase a MF, which one is enough? #56
Yes they are and Iseki makes a great product. I think that some of the newer MF compacts may have a mitsubishi engine; not sure what models though. Still a great motor.
   / Looking to purchase a MF, which one is enough? #57
My Massey GC1710 has an Iseki engine, my Massey 1758 has a Mitsubishi engine.
   / Looking to purchase a MF, which one is enough? #58
Hi, Mike...
Like you I'm a relative tractor noob. I use my MF 1710 much like you want to use the tractor you want to buy and it's pretty close to the 1526 you're thinking about in terms of size and performance. We have 10 acres in the LC Valley and I use mine for road/driveway maintenance, snow removal, spreading gravel, and moving heavy items around. I also planned to use it for some work in a creek bed on the property, mostly moving trees that beavers have felled in the last year or so. I've owned my 1710 for about a year and just sold it yesterday. It simply isn't big enough to do what I want to do with it. Well, it is...it just takes a long time. And I'll darn near have to cut the trees into firewood size logs to move them with the 1710.
I have a new tractor on the way. Not a Massey (out of my budget range for what I wanted) but a TYM. I can tell you from first-hand experience, you're gonna run out of horsepower really quickly with the smaller tractor. At least I did. The 1710 is a great machine and I wish I could keep it because the size makes it very handy...one of it's best, and worst, features. I would say, between the two you're looking at, definitely go with the 1736. I recently got a quote of $33k total cost, shipped to me, for a new 2017 1736 with cab and HST. I thought that was a pretty good price but still more than I could pay.
I opted for a different brand and got a new 46 HP tractor with cab and a few goodies the MF didn't have standard for $28.5 shipped to me. Same tractor without cab can be had for low 20's.
It's definitely gonna be bigger and won't fit in some of the places the 1710 will but it'll do a lot more work in less time. I can't wait to get it.
Good luck with your search.
ETA: Forgot to mention the size thing. I'm not nearly as tall as you and it's a bit of a reach, even for me at 5' 8", to comfortably reach the steering wheel. I almost have to lean over. Also, you pretty much nailed the differences between the E models and the Premium models. One thing is the joy-stick is much easier to reach on the premium machines. Probably money well spent.
I too just bought a TYM product (built to Mahindra specs) and I'm very pleased with the quality, performance and capability. If anyone has a good TYM or Mahindra dealer nearby, I highly recommend taking a serious look at these machines -- built to last and priced well.
Hi, we ended up with a KIOTI CK2610 HST.
The Dealer is very great, the Tractor is working very well. Pics will follow soon.
We added front & Rear Hydraulics and Wicked Grappler. Just ordered a Landplane, which should be done in 2-3 weeks.
Last thing for now, will be a some Pallet Forks.
   / Looking to purchase a MF, which one is enough? #60
Congrats on the Kioti purchase -- I actually considered that model when I was shopping and was impressed with what I saw, and they do have a strong following of satisfied owners. What is a landplane? FYI, I just purchased Titan's 48" pallet fork attachment with integrated hitch receiver, and although I haven't yet used it, based on the weight and construction, it should be a beast. I also bought their 3-point trailer mover and had no problem pulling/pushing around my 8500 lb (1200+ tongue weight) toy hauler.
1992 BOBCAT 743 SKID STEER (A52705)
1992 BOBCAT 743...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A55301)
2020 Westfield MKX...
1990 John Deere 2955 Cab Tractor (A55218)
1990 John Deere...
2024 AGT LRT23 Mini Stand-on Track Loader Skid Steer (A55787)
2024 AGT LRT23...
2019 Kia Soul SUV (A53424)
2019 Kia Soul SUV...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
