Rotary Cutter loose stump jumper
   / loose stump jumper #11
Did you have much trouble re-attachinh the stump jumper to the spline? Is it a one man job?
   / loose stump jumper #12
When I work on a BH, I use my FEL to set it up on its side, then it is no problem to lift the stump jumper up and place it on the splines even with all the blades on it. Just be careful with the blades and pinch points as they will rotate to bottom dead center. A heavy 3/4" drive impact should tighten that nut easily, otherwise you would need to wedge the PTO shaft so it wont turn and use a good cheater bar on a breaker bar to tighten to the closest hole in the castellated nut so the cotter pin will go in.
OH, don't forget to remove the PTO wedge prior to using the mower. BTDT and it isn't pretty when the mower engages.
   / loose stump jumper #14
I also use a loader to put the mower on its side. I also lay down an old tire to catch the upper brackets on the mower as it lays over. Remeber to put some antisieze on the splines. I also scratch a line on the end of the shaft showing where the hole is for the cotter pin.
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
Case 950 8 Row Air Planter (A55315)
Case 950 8 Row Air...
1999 VaXcavator VT500D T/A Towable Vacuum Trailer (A55851)
1999 VaXcavator...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
