losing traction with box scraper
   / losing traction with box scraper #11
Get some weight on it. If you have a FEL, fill it with dirt and try it again with the box blade.
   / losing traction with box scraper #12
Fill the tires.
My BX wont spin at all with the BB on back././ I can sure bog the motor though. Probably would stall it if i didnt let up.
   / losing traction with box scraper #13
I wonder what the difference in tractor weight is between his Kubota and the old Ford. Sounds like he's stepped down in tractor weight.
I pull a 5' BB with my JD2210. I'd guess the tractor weight would be around 1200lbs. I have filled rears and R4 tires. If you get too much material in the box it'll spin and a slight lift of the box stops that.
There's no magic in this, it's simple physics. If the drag resistance of the box exceeds the weighted traction the tractor can apply you spin out. At that point you have to either increase the weighted traction or decrease the drag resistance, hence slightly lifting the box, which accomplishes both.
   / losing traction with box scraper #14
Fill the rear tires and add a lot of weight to the front
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
154 (A52708)
154 (A52708)
2016 Ford F-150 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
2013 Grove TMS 9000E 110 Ton Hydraulic Truck Crane (A60460)
2013 Grove TMS...
2020 Chevy Silverado (A56438)
2020 Chevy...
2023 FORD F-650 SUPER DUTY CAB AND CHASSIS TRUCK (A59823)
2023 FORD F-650...
