Low hour diesel engine failure.
   / Low hour diesel engine failure. #81
So, its been so long that I don't know what information I've posted on here. Anyway long story short, the drive line broke and hit the steering valve and the housing started leaking. So I pulled it out to check the housing to see where it was leaking. I found a couple of bolts lose, so I re-torqued them to see if that would fix the problem. Well here's the part where I screwed up, when I put it back in I reversed two of the hoses on the steering valve (Really pissed at myself, but that’s what happens when you’re doing it at 10pm.). There is a flow through circuit through the valve, and the one hose I swapped was the supply. The supply was now dead-headed so it was putting a load on the pump from the start, thus putting too much load on the motor to start up. This was the initial problem, so there was really nothing wrong with anything else. I couldn't get it to start, and not thinking that the hydraulics had anything to do with it I called the dealer to come get it.
So now the dealer has it, and I told them EVERYTHING (Yes including the valve.) that has happened and what I had checked (Mainly electrical.). They told me that they would check everything, which made me kind of mad because I didn't want to pay them to check something that I already checked. So they went to work on it, they had it over a month and a half test the electrical, and then the fuel systems. Also messing with the injector timing a lot. According to the first service manager (The one that was fired.) he told me a couple times that they had it running a little bit, and thought they were getting close to having it running again. The first time I saw it in their shop, they had the cover plate off the injector pump. Oh yeah, the radiator and hydraulic cooler were off the tractor too. So they probably were running it a little with this hardware off the tractor. I have no doubt in my mind that this is where the motor damage happened. I had never over heated the tractor, and now the head is warped.. Rings are all stuck, and the valves are jacked up.
So they get the motor back together and get it running, and at this point they haven't figured out the hoses are on there wrong. So they run it for a while, find that the steering is not working right. So this is when they find they hoses are on there wrong. They fix this and the steering works fine, but now the hydraulic lines are getting hot. So they then find a bunch of brass in the filter screen, which indicates the pump is jacked up. They rebuild the pump, and supposedly everything is working/running fine. I must note, that I am going off what they have told me. So, what happened behind the seen I do not know. Or what lies I have been told. Remember first they said I dump gas in it.
I fully admit the I missed up on those hoses, but they instant on re-checked my electrical testing. Why didn't they re-check my work on the valve? They are "Factory trained" Deere techs., and they charge $95hr for their work. Any damage that happens behind their doors, they should be responsible for correct?
It does make you wonder what they teach at those Deere factory trained sessions...... Beer drinking 101?
:drink:
I have a meeting today with the manager at 3pm. I am defenatly not paying for any of the motor work, and I'm really thinking I shouldn't pay for the hydralic problems either. Everyone I have talk to about this, and including what you guys are saying is I should demand a different tractor/new motor.. Over all I think I've been pretty cool about the whole thing, I haven't gotten irate or cussed them out. I think most people that have not had their tractor for over three months, probably would have done one of these at this point.
   / Low hour diesel engine failure. #83
I hope all comes out to the good for you. I can understand them wanting to recheck you trouble shooting work. You may not have done things the the same way they would and they would want to know from their own testing where they stand. Since you told them you worked on the steering valve, they should have KNOWN to check your work. Tractor was fine until you worked on the steering valve. Now it will not start. That's the first thing I would have checked. Since you told them about your working on the valve they have no excuses. The shop should have insurance to cover their mistakes. Time for them to make a claim and make things right. If they are self insured, they may fight it, but they caused the damage time for them to make it right.
   / Low hour diesel engine failure. #84
Well I will likely be the odd one out here but I think you are the one to blame. You handed the dealer a puzzle with no clear picture to follow and expect him to just find your screw up right off the bat. Come on, put yourself in that situation and I bet you would do no better. And to expect them to pick up the whole tab.:pullinghair:
   / Low hour diesel engine failure. #85
Well he did tell the dealer what he did. But seems to me that the dealer was the one that screwed up the engine.
Diesel engines are fairly simple, somewhere they should have noticed the extra load or something.
Spraying ether into an engine that is getting fuel doesn't seem to be a smart thing to do.
Also if they were running it with no cooling, again not a smart thing to do.
They probably should have benched the engine and they would have known then that the motor was fine.
Of course pointing fingers and blame is always easier in hind sight.
I didn't say I should not pay anything, I just think I should pay for parts of the problems that I didn't cause. They get paid big bucks an hour, and should not damage the equipment when they are working on it.
   / Low hour diesel engine failure. #87
Switch the steering hoses, this causes the motor to be unable to start up due to the load from the pump. If the OP's description of previous work wasn't relayed properly to the techs, this tractor becomes their nightmare. I bet less than 10% of JD techs would find this problem in a timely fashion if they were never told of the initial problem. Obviously there was a series of errors that lead up to the result. Diagnosis, turning into guessing. Then at some point it was run hot.
Give the new service manager the opportunity to make this right. I'm not sure a new tractor is viable. Even a complete motor might be more than they are willing to go for. A complete rebuild with a warranty might be doable. There has been no harsh words yet and that may work to the OPs advantage. Of course, if they can't find a solution there is always the courts.
Chuck
So, I talked to the Manager (Nice guy). Told him that I'm sure that all the motor damage happened out in their shop. I said there was no issues with my tractor before, and it ran fine. I basically told him that I would be willing to pay for my screw up with the steering valve, because I obviously have responsibility for that. I told him I was going off the information that I was told, which the reliability of that is questionable with the old service manager. So basically I have to go on what my own evidence, and understanding the situation. He really didn't say too much about it, and just said he couldn't authorize this on his own. He has to call his boss to get approval for this. He is losing his position in a month with the new company takes over, so he has to run big decisions by the powers that be. So I should find out Monday.. I haven't had my tractor for over 3 months, and I really need to mow my lawn.
   / Low hour diesel engine failure. #89
Wow -I hope they pick up a nice sized part and make it right for you. Good luck!
   / Low hour diesel engine failure. #90
I would not want a rebuilt engine, op had a low hour tractor that would have likely lasted longer him. I agree it was a really tough trouble shooting job, but using ether......on a such a new,low hour machine, thats just reckless. ( I bet thats not in any Deere training manual)
I can understand them tearing the cooling system off, but running the engine for more than only a few seconds( maybe a minute or two at most) is asking for it to overheat.....again reckless.
I would talk to the Deere field rep rather then the dealer. I would tell the rep you've lost all confidence in the dealership. It s not like you took the tractor to a back yard mechanic, you expected to pay dollar for top dollar workmanship, instead you got recklessness. I would put the ball back in his court. I'd push for a new machine, definitely not rebuilt pump or rebuilt engine.
Don't feel bad about switching the hydraulic lines. I come across that all the time, as a good tech, my job is to find the problem without burning the homeowners house done.
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2010 FREIGHTLINER CASCADIA TANDEM AXLE MID ROOF SLEEPER (A54313)
2010 FREIGHTLINER...
VERMEER 605F ROUND HAY BALER (A51247)
VERMEER 605F ROUND...
Bell B30E 30 Ton Articulated Dump Truck (A52377)
Bell B30E 30 Ton...
