Low Oil Pressure YM1700
   / Low Oil Pressure YM1700 #21
kenmac said:
To each his own but , I put synthetic in my wife's astro van at 60,000 miles . It now has 160,000 on it & still going strong with synthetic oil at 20,000 mile drains !
Astro van? that's not old. When i say old.. i mean like.. 70's.. or antique.. like 50's - 60's.. etc.. Heck.. an astro is practically 'new' in those terms..
Soundguy
Soundguy said:
I emailed amsoil a couple years back and asked their advice in running syn in my old antiques. their response was that if the engine had not been rebuilt in the last 20 ys that they did not reccomend it due to certain seal and gasket incompatibilities. I took their advice.
As for the extra filters.. if it does clean good.. I expect his filters will fill up fast..
Soundguy
It is funny that you mentioned that. The tractor never used any oil until I put some Rotella 5W40 synthetic in it.
It could just be coincidence or maybe the oil cleaned out the engine too much. Since then I have been using Mobil Delvac 15W40. I am not really sure what to do. Someone mentioned that Shell said some oil usage was normal for the first couple of oil changes. If that is true maybe I did not stick with it long enough.
   / Low Oil Pressure YM1700 #23
Hard to say... I'm not a fan of switching oils around frequently.. however.. if you have carbon sludge sealing something that wasn't leaking.. then that sludge got cleaned away.. I might expect some usage.. etc.
Again.. I'm not criticizing syn oil.. i'm just question it's application is certain cases. I know for my antiques.. it was not recomended, right from the 'horses mouth'. As for my newer tractor? I think I'd rather change the oil at less than the oem interval, and just use a good diesel rated oil, and oem filter. I'm quite sure that my older 1975 ford 5000 never got anything better than that.. and it is holding up nicely. I fully expect my 7610s to do the same, or better under the care I give it.
If oil technology drastically changes in a few years, and a miracle 'fit all' lube comes out.. I'de be inclined to try it.. it if fit the paramaters for my application.
Soundguy
   / Low Oil Pressure YM1700 #24
I put synthetic oil in a fairly new rebuilt vw engine once... She threw a rod.. I always thought that oil had something to do with it. I never used it since...on anything....
   / Low Oil Pressure YM1700 #25
Come on now sound guy . 1st you say old , now you are saying antique . If your car / tractor leaks with stnethetic oil , it's because it lubricates better ie, getting into hard to reach places that your dino can't reach. This is why dino usually won't leak out of the seals & in some cases synethetic will . Synethetic has lubrication properties that dino can't match. funny that my 25 + year old yanmar doesn't leak with synthetic. Is that old enough for you ? Just think how good your ford 5000 may run with synthetic if it runs well with dino .
   / Low Oil Pressure YM1700 #26
If you will re-read my original message, you will notice that I mentioned '70's
Many of our yanmar fall into that range.
Old? antique? where is the hard line in the sand? I don't see one? A vehicle from the 80's.. while old for driving standards perhaps.. is not specifically old mechanically. For instance.. take a tractor from the 80's. Could still be like new, even if well used.
Move back tot he 70's and you can see some age creeping one. Every decade you move back you see more age. Specifically as design styles chaged, and you start seeing art deco in the tin work.. etc. Looking at the profiles of many tractors from the 80's, 90's and 00's, they virtually look the same, model dependent. ( boxy models ) Of course.. now with the sloped hoods and contoured body panels coming in very mainline right now, that now 'dates' the boxy models to a different era. etc.
So yes.. old / antique... I don't see an argument point.. it's all grey area.. not black and white.
I'd also bet the enhanced cleaning properties of synthetic lend to some of the leak issues when it is introduced to an older vehicle that has run on dino.. etc.. especially one not maintained very well.
While I'm not knocking synthetic.. I also don't see it as the magical savior of the future.. not yet anyway. Significant engine work was done int he 20th century on quite old oil technology. many of us collectors have vintage equipment only run on older oils.. even non detergent oils, and lower/older grades, and have units that are oem and still within tolerance. Move up a bit and look at more moder dino lube technologies and other engines, and you can see that if you maintain a vehicle, keep clean oil in it, that it will last, if it was designed well.
We bought an 84' mack tractor from a milk plant. They had had the truck since new.. we bought it with about 800K miles on it. The service logs for this truck showed that it had never had engine work.. not even the finicky air compressor. Just oil changes and lubes, and seals and bearings ont he wheels.. etc. Crankcase held 10+g of oil.. It was being run on bulk diesel rated fina 30w, per the service records. We dropped the pan and plastigauged the mains... they were so far in tolerance, we buttoned her back up with a new pan gasket and put her right on the road with out changing the shells.
Now.. if dino oils is so bad.. that couldn't have happened. Truth is, synthetic may perform better.. however, engine technology from the 20th century was running fine on dino. Specific problem areas like hi-temp, hd turbo systems, and high tolerance areas were greatly benefitting from the improvements in synthetic oils. the key is maintenance... If you have a quality product, and maintain it per the manufacturers specs.. you should expect it to last up to, or past it's designed service life... etc. <ost of the engine problems I see on tired old worn out machines are from outside damage, mis-use, abuse, and abject neglect, malicious acts, and improper maint techniques, fluids and aprts.. etc.
A loose hub retainer nut is going to make more difference to the service life of a spindle and bearing set, and thus seal, than the difference in an 84 Cent per tube cheapy TSC grease, vs a 5$ tube of synthetic grease, when the bearings are packed.. etc.
Soundguy
   / Low Oil Pressure YM1700 #27
Here's your 1 st post Chris .(Your original message is your 1 st posr on this topic . Isn't it ?) May I call you Chris ? It's says nothing about 70s . It says old machine .Now you did mention 70's in another post but , not your 1 st.My wife still says her van is an old machine to her. & what about my yanmar did mention, I had synthetic in it . ? Anyway, no leaks & no oil use. This may not be typical but ,it worked & continues to work for me. Not only on my yanmar but , all my motor driven toys/ vehicles.
'' I'd have a few filters on hand if you do the synthetic flush route.. me personally on an old machine? I wouldn't do it.. ''
   / Low Oil Pressure YM1700 #28
Usually only my friends call me Chris.. but anyway...
I still can't figure out why you are being abusive with the point. We are just having a discussion here. Do you get up and stand on the table when you talk to a group of people?
Again.. My -personal- intention, is that I would not add it to an older machine. Why? Again.. because one of the larger synthetic oil companies made that recomendation. If I'm to believe any of their recomendations about their oil products.. then i don't see why I shouldn't believe that one as well.
There's not much more for me to say on the subject of my opinion.
Soundguy
   / Low Oil Pressure YM1700 #29
I, like Soundguy, also fail to see your point:rolleyes: .
   / Low Oil Pressure YM1700 #30
There were seal material incompatabilities when synthetics were first introduced to the public, but that was the main problem, not lubricity or washing out the old crud.
FWIW, I think synthetics are pretty good, but not necessary for everything. I have an Audi twin turbo - I run Sythetic in it to help keep the turbo's from coking up - as a side benefit, it gets 2 mpg better mileage!
But for my 90k mile Lexus, my tractors, mowers etc, regular old multiweight oil is just fine..............
Adams 5 ton Fertilizer Buggy / Wagon (A53472)
Adams 5 ton...
New/Unused 72in Quick Attach Mower King Hydraulic Brush Cutter (A51573)
New/Unused 72in...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2016 KENWORTH T680 TANDEM AXLE MID ROOF SLEEPER TRUCK (A52576)
2016 KENWORTH T680...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
