Lowery Mfg (LMC) Rotary Cutters?
   / Lowery Mfg (LMC) Rotary Cutters? #21
I'm still looking at getting a rotary cutter. I've looked at the $1000 models and then at Woods, Bush Hog, Land Pride & Brown. Its easy to see why they are more expensive - more steel, heavier steel, better welds etc,etc,etc. I'm impressed with the Brown 416 and trying to find a local dealership. So far - no joy.
I'd like to say that any cutter I end up with will have an easy life but in all reality that just won't be the case. Too much hidden stuff and the need to mow down brush and saplings.
Sounds like you made a good deal on the finish mower. Now go easy & be safe.
   / Lowery Mfg (LMC) Rotary Cutters? #23
Trying to find a manual or gearbox info for a poster on here, so looked around on the Lowery website. One place they clearly save some $ is in creating and publishing user documentation/manuals! He has a "Clipper 400" with (evidently) a gearbox made by "Cheetah". Not a shred of info about either on the website.
   / Lowery Mfg (LMC) Rotary Cutters? #24
Here's a start:
Go to: howseimplement.com/gearbox-100hp-7-8-cutter-cheetah-pg-167.html
   / Lowery Mfg (LMC) Rotary Cutters? #25
Thanks! Funny how both LMC and Howse each have a "model 400" with a "Cheetah" gearbox. At least Howse has the full cutter manual available for download, which should include the info the other poster needed.
   / Lowery Mfg (LMC) Rotary Cutters? #26
I have an old Andy 500 that I have used and abused. The nut for the stump jumper/blades has lost the cotter pin twice and everything dropped out the bottom while mowing. New nut and pin put it right back in business. I've cut 3" privet and 4" pines with it if my tractor would ride them down. My Yanmar YM3000 handles it just fine. Next weekend I'll be buying a Kubota L3430HSTC and will buy a new 5' Lowery cutter to go behind it. I think I'll get the square 'Standard' model.
2018 Ford F-550 4x4 18ft Rollback Tow Truck (A44571)
2018 Ford F-550...
2015 INTERNATIONAL 4300 26 FT NON CDL BOX TRUCK (A43003)
2015 INTERNATIONAL...
2014 SHERMAN + REILLY CABLE TENSIONER (A43004)
2014 SHERMAN +...
Ground Hog HD99 Hydraulic Earthdrill (A45336)
Ground Hog HD99...
2001 STERLING M7500 FLATBED TRAFFIC CONTROL TRUCK (A43003)
2001 STERLING...
2014 Infiniti QX70 SUV (A44572)
2014 Infiniti QX70...
