Ls tractor and log sitter
   / Ls tractor and log sitter #11
For occasional use, tying up your tractor to split wood slowly might be OK.
Seems silly to me to run a tractor when a small gas engine on a dedicated splitter will do the job faster.
If you are OK with slow, and do not split a lot, look at an electric unit if you can get the rounds near an outlet. No gas or oil issues to deal with.
   / Ls tractor and log sitter #12
i did the splitter off the tractor many years ago and i'm still a believer because of the reasons that many have already listed:
one less engine to maintain - it seems that I always have a carb that needs cleaning.
how many hours will you really add over the life of the tractor?
convenience - set the height so you aren't hunched over, drop to the ground to roll large rounds on.
sure, the downside is speed, but...
I built my splitter with an 18" stroke cylinder because my stoves are meant to burn 16" logs. I don't waste any time cycling up to the log before it starts the split and it doesn't have to retract as far.
a stand alone with a two speed pump is faster with no load, but i believe mine is faster when it is in the wood.
I don't have any help most of the time, so by the time i finish the split, kick the handle into retract, put the split piece where it needs to go, and grab the next piece to split, it's already waiting for me.
I had a power beyond set up on my tractor already, so it was simple to do, as opposed to a bungee on a valve, but whatever works.
I found that on my old tractor (JD770) i had to run around 2000 rpm to get a reasonable flow out of the 5.6gpm implement pump. you may need to run faster to get the power & cycle time you need if you are on a 4.6gpm.
   / Ls tractor and log sitter #13
I have a 3 point splitter and really like it but I don't know if it's the best choice for you. I have rear remotes. Using the loader connections would be awkward for me and require really long lines. I also have a two way splitter which makes the speed OK. I would not be happy with a one way splitter that I had to have a return cycle for because of my limited gpm. Two way splitters seem to be rare these days.
   / Ls tractor and log sitter #14
I agree with everything you mention and I do the exact same thing.
I have 8.9 gpm at 2600 rpms, but I only run the engine anywhere from 1200 to 1500 rpms, which puts me around 5.15 gpm. I just hold the remote lever with a piece of wire and it's good to go.
For the occasional use, this is plenty good for me. I also only have a 3.5" bore cylinder, then again, good enough for my needs. Not to fast, not too slow. Just right as I'm not in a race anyway.
Having a dedicated engine for the log splitter, it's just another one to maintain plus the gasoline is very expensive here (7.20 US$ / gal) versus diesel ( 4.96 US$ / gal). I only run gasoline for the chainsaw and the lawn mower really.
If I was splitting wood in high volumes to sell, I would definitely come up with something a little faster, but just for the homeowner, this setup is plenty good.
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
Case 1840 Skidsteer (A59814)
Case 1840...
CFG Industrail MX15RX (A53317)
CFG Industrail...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
