Lug nuts/bolts doing a Peter Pan
   / Lug nuts/bolts doing a Peter Pan #21
In almost 50 years of driving and 10 years of working on cars and trucks for a living I never seen a properly tightened lug nut come loose
   / Lug nuts/bolts doing a Peter Pan #23
You have led a blessed life.
I have seen loose lugs while working in the garage but I have never had any on my personal vehicles. I am also blessed!
   / Lug nuts/bolts doing a Peter Pan #24
Me to a torque wrench must be my friend.
   / Lug nuts/bolts doing a Peter Pan #25
Have to agree with you here.
Owned a repair shop for over 30 years. Hand torqued wheels properly torqued should never come loose.
Best fix for his tractor would be reaming the axles for oversized studs. Get another reamer the size of the oversized studs and drill the wheels. Then find the max torque for what he is using.
   / Lug nuts/bolts doing a Peter Pan #26
I dont agree that the hub is toast. The lug bolts dont seat on the rim, they just hold it tight to the hub on the tractor (note photo center hub). The rim is seated on the center hub so it should be good if you just sand the bolt holes flat to remove any protrusions caused by the loose bolt wobble then install new bolts. Fastenal has some special two piece lock washers called Nordlock and they wont loosen off. The front hubs on my LS kept loosening off and after twice tightening them, I got all new 10.9 bolts and the special Nordlock washers and they have been tight ever since.
You may have to chase the threads on the tractor hub. I would look at running a thread tap in from the back side to clean the threads. Much easier that way than trying to start it from the buggered thread side.
   / Lug nuts/bolts doing a Peter Pan #27
It is a piloted hub which has gone unnoticed here by most but the bolts still have to resist rotation. If they’ve been wallowed out they might allow it to rotate back and fourth and get worse. I agree that welding 2 holes to a tight fit is the best thing to do.
   / Lug nuts/bolts doing a Peter Pan #28
So many tire shops have no idea what a torque wrench is.....
Its funny watching many mechanic/car shows on TV how many people just run the lug nuts on with a impact
   / Lug nuts/bolts doing a Peter Pan #29
LOL, not really. I did have one place that did my tires leave one wheel extremely loose.
   / Lug nuts/bolts doing a Peter Pan #30
I checked my lugs tonight.
405 hours and all is well.
2008 Ford Focus Sedan (A53424)
2008 Ford Focus...
New Holland 650 (A53317)
New Holland 650...
2017 John Deere 8370RT Track Tractor (A53485)
2017 John Deere...
2014 Peterbilt 337 IMT 10,000LB 5 Ton Crane Mechanics Service Truck (A53422)
2014 Peterbilt 337...
(5) 12" X 22# X 171.25" (3) 12" X 22# X189" I BEAM (A57192)
(5) 12" X 22# X...
John Deere 1025R (A53317)
John Deere 1025R...
