Lumpy lawn--How to smooth?
   / Lumpy lawn--How to smooth? #11
I was looking in the Northern Tools catalog at rollers you could pull behind a lawn tractor. I see they have a Poly Roller and a Steel Roller. Obviously, the steel roller is larger (24"x48" vs 18"x48") plus it's steel so it would be heavier. But would either of these be substantial enough to compact a lawn or would something larger and heavier be needed?
   / Lumpy lawn--How to smooth? #12
Get the steel roller. It is a lot heavier 900lbs with water I believe. I have one and yes it is substantial enought to make a big difference if the ground is a bit soft from moisture. Nothing will smooth out dry ground though. We usually roll twice in the spring then drain the roller for another year.
   / Lumpy lawn--How to smooth? #13
I didn't go the roller route. I used my rear blade w/ gauge wheels to spread sandy loam I got from my creek area. I can set the blade height to where you can just start to hear it tearing the grass, then raise it a hair. After spreading, I just keep diving over it a bit to campact. Then, spread a top coat and leave it. The grass grew thru the fill easily and spread on it's own to fill in.
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
2020 BOBCAT T870 SKID STEER (A52705)
2020 BOBCAT T870...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A51247)
JOHN DEERE 635F...
