lx 2610 box blade weight?
   / lx 2610 box blade weight? #1
coldfingers
Warren, Mn.
2013 Kubota RTVX-1120D, kubota ZG 227, kubota LX 2610
How heavy of a box blade is okay on a 2610? I'm just using it for snow removal, "72" at 550 lbs okay?
   / lx 2610 box blade weight? #2
If exclusively for snow removal that will be fine.
But......
1) Most here use a rear/angle blade for snow removal, so snow can be windrowed to the side or pulled.
2) 72" Box Blade is a too wide to use as TPH counterbalance for FEL lifts. Total width of a 72" Box Blade will be cumbersome ~78".
3) Consider a snow box so your snow work is in front of the tractor. Much faster snow movement so you can return to the warm house sooner.
YouTube VIDEOS:
https://www.youtube.com/results?search_query=tractor+snow+box
Do not compromise on implements. Search until you find exactly the right implement in exactly the right size and weight.
I pull my snow about 75 yards and pile it then
   / lx 2610 box blade weight? #4
I'm thinking that pushing snow is easier than dragging. One big positive about pushing is that you smooth out the surface ahead of your travel: that's why dozers have blades at their fronts! ;)
   / lx 2610 box blade weight? #5
I have a 60" HLA snow pusher with the back drag option and have to say I'm a big fan of it. It is heavy but it is impressive how much snow you can push with it. I also like the back drag for around the house and shed. It cuts down on a lot of shovelling.
I'd second the rear blade recommendation over a box blade and if I didn't have a rear blower that would be my first choice over a BB.
Thanks guys
2005 MERCURY Grand Marquis Sedan (A56859)
2005 MERCURY Grand...
Auger Drill Bit (A56857)
Auger Drill Bit...
Truck Metal Cargo Storage Box (A55787)
Truck Metal Cargo...
New Landhonor Heavy Duty Plate Compactor (A59000)
New Landhonor...
2021 ASV RT-120F FORESTRY SKID STEER (A52709)
2021 ASV RT-120F...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
