Lx176 without ignition
   / Lx176 without ignition #11
I read the guidelines on this site. Nothing about TBN being responsible for the postings of the community.
So while I share your concern for the safe operation the equipment, there is nothing that requires the owner/operator to keep all the safety equipment in working order.
A lot of us have seen advise given turned against the person who provided the advise because the receiver did not have a pot to urinate in and when he got hurt he sued the person who provided the information or advise. They always say if they had not been provided the information they would not have know how to by pass the safety interlocks which caused the injury.Idiots love to sue others, they have an adverse mental and physical reaction when told they cannot sue themselves for causing maiming injury to themselves.
   / Lx176 without ignition #12
Kransbox,
You know you only need a few controls to start and run you engine.
1. OFF/ON switch connected to the spade terminal on the coil. Connect the terminal to ground, engine stops.
2. Push button to activate the starter solenoid.
3. Throttle and choke controls.
To operate the mower deck PTO. A simple switch or a switch connected to a solenoid that then operates the clutch pull-in coil. I would suggest using a solenoid for the PTO as it draws quite a bit of current which can shorten the life of most common switches.
You will also need the alternator and voltage regulator to charge the battery.
Don't hurt your self of others in the process.
Good luck,
Richard
Champion Vibratory Roller (A60462)
Champion Vibratory...
2022 John Deere 1025R (A53317)
2022 John Deere...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
Krause Dominator 4850-18ft (A56438)
Krause Dominator...
2015 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A59230)
2015 Freightliner...
2020 Ford F550 - 6.7L Powerstroke Diesel -54k Miles (A56438)
2020 Ford F550 -...
