I get your point about when you use the rear wheel lock and why. Another way to look at the function is that it guarantees 3 of the 4 wheels are pulling while a normal 4WD without the rear wheels locked (differential defeated) only guarantees 2 of the 4 wheels are pulling. I do wonder though -- unless you are experiencing wheel spin while operating (are you?) then I don't see how the wheel lock does anything for you.Tillage and grading. With the 4 wheels clawing through the traction is uneven at times. The diff lock balances this out.
It also helps significantly with an angled blade grading where the machine is getting shoved sideways.
I would say you are asking the tractor to do more than it is designed for and using the diff lock probably isn't the best solution based on similar experience with my L4400.That is exactly the issue. With tillage and grading the wheel slip is enormous. In the picture I was crabbing to stay on the path I wanted. Without the diff lock it was worse.
