M5140 questions
   / M5140 questions #31
So it is ok to just place the hand lever in the mid position and leave the transmission in gear 5 minutes I believe on a std manual tranny if you held in the clutch for 5 minute the throw out bearing & clutch fork (contact points) would wear faster. Hope my question is some what clear ??
Given the neutral start switch is on the shuttle lever that should tell you right there that Kubota is ok with that lever staying in N.
2005 Sterling Acterra Tender Truck (A56438)
2005 Sterling...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
Green 4ft X 50ft Vinyl Coated Lawn Fence (A56860)
Green 4ft X 50ft...
2005 MACK CV713 TRI AXLE 16FT DUMP TRUCK (A59575)
2005 MACK CV713...
Craftsmen Air Compressor (A57454)
Craftsmen Air...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
