M59 HST no go?
   / M59 HST no go? #1
M59 gray
Kubota M59
Hello to all,
I have made the move from an L48 to a used M59. It needed some tlc as it was a rental I think. I fixed up the hood and side panels. Repaired the steps and some cover plates. Time to hop on/??
I ran it around the yard a bit a few days ago , all seamed OK. After parking it and doing some cosmetics on it and the filter and fluid changes I was ready to put it through its passes to see how it worked.
Start up good. Clutch good. Medium range good. But----- no go???? No matter what range It will not move???
Foot linkage seams OK. Gear range linkage seams OK. No panel codes.
It ran good a few days ago and now nothing????
What to check for?
Is the Control module causing it?
Any ideas?? Help please.
   / M59 HST no go? #2
Similar problem solved here. It might help.
   / M59 HST no go? #3
When you "changed fluids" did that include the transmission fluid? Would have been pretty large quantity of transmission fluid. You sure the control linkages are in place ? Do hydraulic things work while you have the engine running (like 3pt lift, loader if it has one, etc.) ? What does it mean when you say the "Clutch Good and Medium Range good" if the tractor won't move. That doesn't seem to make sense.
Very strange. Good luck...
   / M59 HST no go? #4
Model year will be helpful, my 2015 is drive by wire so no control linkages just wires to the pedal and wires to servo for fwd and servo for rev
If you aren't in gear (low-med-hi) you won't go. Clutch in when switching ranges
   / M59 HST no go? #5
Hello to all,
What to check for?
I doubt it is a control module. Nobody has had a problem with one yet. My first guess is that one of the cable operated levers or drums connected to the foot treadle pedal has broken. That happened on mine. The throttle cable under the floor that went from the foot pedal to a drum underneath and a few feet toward the rear of the foot pedal had broken inside the cable housing.
My symptoms were the engine would start and idle, but would not move. When I put it into a range and moved the foot pedal it wouldn't rev up enough to engage the HST and move. Then I found that if I pushed the HST pedal and simultaneously reved the motor with the hand throttle on the side "dashboard" the HST would engage and it would drive. That was enough of a hint to be able to find the problem.
Finding the problem took longer than I thought because normally a cable breaks at the end and is obvious, but this one broke a few inches back from the end and inside of the cable sheath because of the way that the cable wraps around the drum. Fix took about half an hour and a new cable.
If you have to or want to take off the side cover/instrument cover to get at the wires to the HST controls or the display it involves taking the rubber grips off of the handles. The grips just slide off. Take a piece of wood and cut about a 12" slot down the middle. That will give you a lever to slide over the steel control and push the rubber handle off. Be careful of their short wires. Especially the wire to the control button/lamp on the front of the cover. It is short & can break that indicator light switch.
let us know,
rScotty
   / M59 HST no go?
Hello, I am in process of trying to fix now.
I disconnected the battery and left it off for a while as one person said that can reset the ECM?
I checked the pedal connector and added some anti ox grease.
I will track down the cable you mention? My throttle advance is working so if that is the one you are speeking of it is good.
I will try to see if I can read any codes the unit can offer??? I dont know if I can get it to speak to me?
More in a bit.
   / M59 HST no go? #7
I do not know how much control that the ECM has over the functioning of the transmission. Maybe someone else can answer that.
I have one of the first M59s & have followed them since. I do not recall any ECM problems ever being reported. I doubt that disconnecting the battery will do anything. Have you looked in the service manual to see what help they offer? It's a good manual.
Problems of any kind for the engine and transmission seem very rare and I don't recall anything electrical. This is a pre-tier 4 tractor, so the computer is very simple. I'd look for something mechanical and simple.
   / M59 HST no go?
Its a 2009. It is a fly by wire. The Pedal control reostat sends info to the CEU and that sends comands to the HST servos. I ran a check on the errors thanks to the info posted some time ago on this site and found the HST error 81 and throttle error 84 and forward proportional valve error 90. I decided its the throttle control that is the trouble and the other two got switched on because of the throttle. I ordered a new control. Now the frustrating wait for it????? Hope it solves the issue. thoughts?
Thank you.
   / M59 HST no go? #9
Thank you.
   / M59 HST no go? #10
Thank you.
Can you post the link to how to check for errors?
   / M59 HST no go? #11
Your troubleshooting and repair outcome details will be appreciated from another M59 owner. Learned a lot from others on this site.
Sure enjoy operating the M59. The transmission gearing and HST-plus is a big improvement over the L48.
   / M59 HST no go?
I replaced the throttle sensor as the error code indicated. No change?
All things including hydraulic functions are good. No known lockouts are engaged.
It was running good then a couple days after parked —-no good?
It goes into gear. Clutch sound like it’s engaging and loaded by pump.
Zero travel response???
Ideas?
   / M59 HST no go? #13
Did you get any info reading through the thread that Chewwy mentioned?
That thread also includes some photos from the workshop manual.... Not very useful
for resolution. Most of your questions about how it works are answered in the workshop manual.
You might also find information in the old M59 Discussion Thread that Charles started back in 2007/2008. There is over 40 pages of information there. Most is not technical, but some is.
rScotty
   / M59 HST no go? #14
Probably not the problem since you are familiar with L48. I buy used and the three HST models B20, B26 and M59 had bent and stiff range selector levers from improper shifting techniques from previous owners. Now after straightening and using properly, taking time up to 30 seconds, they shift normally now and align with the position letters.
You didn’t say or I missed if you tried the different ranges to eliminate the different gears.
There is a hook that keeps the clutch pedal depressed for storage.
   / M59 HST no go?
Update:
Shift lever is good
Tried all ranges -no go
Clutch latch is not engaged
Could a spot of frozen water in a fluid port cause it? Been mid 30 but just a question?????
   / M59 HST no go?
I did look back at the older posts but will now look at the other in case?
Thanks!
I’m just totally befuddled? Work good. Parked it for a weekend then no go?
   / M59 HST no go? #17
The backup alarm is also tied to a safety switch. Can’t just unplug to not beep. Reverse pedal does it sound?
   / M59 HST no go?
I used the info from an old post?
As I recall: you push both the Display mode and Travel speed buttons on the control council and while held down turn key to start
ABCD shows then push Display again and EFGH and others show then hit Travel to see what code is displayed
I think you can continue to push Travel in case other codes are shown?
This info is by memory but once you try it you will see how easy it is?
   / M59 HST no go? #19
Thanks!
Well, in that older post with the same problem, he found that the problem was a shorted switch which then sent the wrong signal to the CPU. I forget which switch it was, but it's in that thread. It worked for him..
   / M59 HST no go?
Yes, I read that. My column speed shifter seams to trigger properly as read on the panel. Still may be but does not seam to be it?
I’m going to double check the reaction control rotary switch tomorrow? Could be as I took the cover panel off and had to remove that switch? May have damaged it? It does control over the speed of action?
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
2016 Ram 4500 Chassis Ambulance (A59230)
2016 Ram 4500...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
