M7040 industrial tire pressure
   / M7040 industrial tire pressure #1
Dave M7040
Elite Member
Williamstown Ontario Canada
Kubota M7040 Nuffield 465
I have a new M7040 with FEL and cab which came with industrial tires.
The front tires are 12.5 x 20 MITAS which is a size not shown in my owner's manual.
The tire sidewall has a cautionary label about only qualified people servicing the tire but there is not a max pressure shown to use to seat the beads nor a pressure and load rating at that pressure.
The rear tires have a label which says max pressure for setting bead is 35 psi. Rear tires are 16.9 x 28 and there is a pressure shown in owner's manual of 18 psi.
During a recent snow storm, one front tire came off the bead which caused a few headaches I was not expecting with a new tractor with 30 hrs on it.
Does anyone have information on the pressure I should be using and further why would this information not be on the sidewall?
Dave M7040
   / M7040 industrial tire pressure #3
i have a 7040 with r1s 30x16.9 rears 24x9.5 fronts 26 psi in the fronts 18psi in the rears that pressure kenny is to high i got that out of my manuel that came with the tractor
   / M7040 industrial tire pressure #4
how do you like your tractor so far i have the gear tranny i should of gotten the hydrilic shuddle clhuting is a pain
   / M7040 industrial tire pressure #5
If you have a loader, you get in the habit of watching the front tires when carrying a respectable load. That's often a tip-off that they are low. Another seat of the pants method for telling if a tire is low is how the tractor handles on pavement in road gear. Low tires will often set up a bouncing motion front to back or pull to one side.
   / M7040 industrial tire pressure #6
That is not going to be a recommended tire pressure for any particular application...
That is The Tire Manufactures Rated tire pressure for His particular tire.
You should run tire pressure according to various variables...
   / M7040 industrial tire pressure #7
u cant fill a tire solid full of air a tire needs to flex to much are with a heavy load the tire will blowout
KennyV
I had seen the Mitas web site previously. My tires are MPT-04 but 43 psi seems high for a farm tractor and I was not certain if the rims were designed for the full load capacity of the tires.
To Case245: I really like my tractor but compared to 35 years with my Nuffield 465 it is a dream. I am struggling to get used to not touching the clutch pedal.
Dave M7040
1995 International 3800 Water Truck (A47307)
1995 International...
2008 Audi A4 Sedan (A46684)
2008 Audi A4 Sedan...
600 Gallon Aluminum Tank (A46683)
600 Gallon...
2012 VVF HEATER (A47001)
2012 VVF HEATER...
2015 Ford F-750 Terex Hi-Ranger 5TC-55 55ft Insulated Bucket Truck (A46683)
2015 Ford F-750...
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A45336)
2013 Chevrolet...
