Mac Tools AW434M Impact Wrench
/ Mac Tools AW434M Impact Wrench #1
deere5105
Veteran Member
South Mississippi
2008 John Deere 5303 MFWD, 2004 John Deere 5205
I received a new impact wrench last year and am ready to put it to use on a winter project. The old one I have been using is cheap and has below average torque. It came with a small bottle of oil and I have always put a couple drops in where the air hose connects each time I have used it. It still works ok and can be used for light duty projects.
I am curious what the recommended service/oiling is for an impact wrench and what type brand oil is most everyone using. The manual stated to order the Mac Tool Oil, but surely there is something I can pick up locally that will work just as good. I want to start off on the right path and expect this tool to last me a very long time. Any suggestions on what to use and how often to oil?
/ Mac Tools AW434M Impact Wrench #2
We use a lot of air tools ot work. We put in a few drops of Marvel mystery oil before each use. You should be able to find that locally. Any store that sells air tools should carry some sort of oil for them also.
/ Mac Tools AW434M Impact Wrench #3
I use Campbell Hausfeld oil, you can get it at Wallyworld, or at Tractor Supply.
I searched for air tool maintenance tips on Google after posting this. Saw one link saying use Marvel to clean a gummed up air tool. The link mentioned continued use of this oil would dry out seals causing a need for repair. I noticed your profile stated you were an offshore mechanic by trade. I would think your occupation uses air tools quite regularly. Have you seen this to be the case? I read several articles about in line oilers and such, but honestly I don't expect to use this tool more than once a month. I have no problem manually oiling it. Is there much more or anything else needed beyond putting a couple drops in where the air hose attaches to the tool?
/ Mac Tools AW434M Impact Wrench #5
The MAC AW434 is a very good impact wrench; rebadged Chicago Pneumatic CP231.
I would not use regular Marvel Mystery Oil for the reason stated by deere5105. However, they make Marvel Mystery Air Tool Oil which is what I used when I was in the business of working on air tools because I got it by the quart. But now, I used Campbell-Hausfeld because it's conveniently available at Walmart in small bottles, as stated by buggyman1.
Any oil is better than no oil, but any oil sold as being specifically for air tools is the only oil I'd use.
And a few drops of oil into the air intake before use is good, but even better is a few drops after use. Put a little oil in the air intake, one quick shot of air to distribute it, then put it away. That will go a long ways toward preventing corrosion.
And for anyone who doesn't already know it, you cannot hurt the tool with too much air tool oil. Any excess will be blown out the exhaust when you start. However, depending on which direction the exhaust is aimed, you may not like getting all that oil on your work or on your clothes.:laughing:
The tool I have been using is a $30 tool that come with the compressor in a kit when I bought it. I was less concerned over being specific when purchasing oil than I am with this new tool.
Seems like I saw somewhere that the wrench uses full torque when in reverse and the adjustment regulates forward torque. Any truth to that or does the torque regulator control both forward and reverse torque? I hope this tool will perform better at 625 ft lbs compared to the older tool being around 200 ft lbs. If performance not as expected, I suspect I will have to evaluate the air compressor.
/ Mac Tools AW434M Impact Wrench #7
I guess I could be guilty of air-tool neglect.
I do use the crap out of my air tools. Especially my IR2135 impact and my HF cut-off too and HF die grinder.
I dont oil them very often. Maybe one every month or two when I think about it:confused2: And it is usually never air too oil. It is just whatever I have around. Sometimes the 10w30 that is in my oil pump can, sometimes a shot of WD40, sometimes a little ATF, just whatever.
Never had any air tool issues related to lubrication. the 2135TI is now ~4 years old, and still going strong
/ Mac Tools AW434M Impact Wrench #8
Air tool repairmen love folks like you.:laughing::laughing:
/ Mac Tools AW434M Impact Wrench #9
I'm not sure about that particular model, but most impacts do have an adjustment for forward and always full power in reverse. And they keep making very minor changes or improvements. The old original IR231 was rated at 425 ft. lbs. I currently have an IR231H-2 rated at 450 ft. lbs. I've overhauled MAC AW434 and AW434B, but not the AW434M. Been out of the business for 10 years.
Very few people ever turn the adjustment down on air tools except on assembly lines. To keep from overtightening something, you just don't hold the trigger open as long.:laughing: Not really every accurate? Of course, but good enough for most things, especially if you intend to finish with a manual torque wrench. The torque "adjustment" on air tools simply partially closes the air tool passage to reduce the volume of air allowed through.
/ Mac Tools AW434M Impact Wrench #10
Unfortunatally, I have never used the services of an "air tool repairman"
My HF stuff is throw-away anyway. Who actually expects a $7 die grinder to last anyway??
And IF/When my IR2135 ever fails me, I wont get it repaired. I will get a new one for ~$300. Because so far, even if mine quit tomorrow, I have gotten well over $300 worth of use out of it. The first two years of its life was with me on the job at the factory I worked. Industrial Maintenance. It was used daily:thumbsup:
/ Mac Tools AW434M Impact Wrench #11
I was partially, but only partially, kidding you. You may go a long time without a problem, just as many people lived long lives without ever wearing a seat belt. it's just a matter of playing the odds. A very general rule of thumb is to repair an air tool if it costs no more than 50% of the price of a new one.
But there's certainly nothing wrong with cheap throw away tools either. My first air impact was from Habor Freight, rated at about 210 ft. lbs. and it lasted many years. Some things it just wouldn't do. And of course such tools are not worth having them repaired if they break. I currently have a 3/8" air ratchet and an angle die grinder from Harbor Freight; cheap, but do what I need. And as you said, if one of them breaks, I won't waste time or money fixing them; I'll just go get another one.:)
/ Mac Tools AW434M Impact Wrench #12
Lucas Oil makes a good air tool oil and so does Blaster. I have used both with no problems.
I didn't write the numbers down, but while airing up tires this afternoon I believe the sticker on my compressor state 4.0 CFM at 90 PSI. This is a Kobalt upright unit I picked up at Lowes. I could be wrong, but think it might be a 26 gallon tank. Any thoughts on it being adequate for the tool discussed above? I believe it had a chart on it that listed it as adequate for Impact Wrenches.
/ Mac Tools AW434M Impact Wrench #14
I would imagine the specs for the impact will call for an average air consumption of 4.2 to 4.5 CFM at 90 psi. For a lot of people and uses, you'll find a lot of opinions that you don't have enough compressor. But for your personal use, I'll bet you do. Now if you have a lot of tires to remove; i.e., lots of lug nuts (or bolts) and they're tight so the impact has to hammer awhile to loosen them, and you rapidly go from one to another, you might have to pause to let the compressor catch up sometimes. But for one or two nuts or bolts, or for one tire, you'll probably find it works just fine.
It just depends on how much work you have to do, and how big a hurry you're in.
Did some more checking and it seems there is no one brand of air tool oil recommended over another, unless it is by the manufacturer recommending there brand. Talked with a friend who runs the shop at a local car dealer. Got basically the same feed back from him. Dropped by local parts store this afternoon and they had the Marvel Mystery Air Tool Oil. Picked up a small bottle of it for less than $5.00.
Thanks for all of the input and suggestions.
/ Mac Tools AW434M Impact Wrench #16
And for anyone who doesn't already know it, you cannot hurt the tool with too much air tool oil. Any excess will be blown out the exhaust when you start. However, depending on which direction the exhaust is aimed, you may not like getting all that oil on your work or on your clothes.šŸ˜†
Hello Bird,
I am brand new to the Forum but an old guy on a farm. I got tired of making do with tire irons and decided to buy an impact wrench. The new battery powered ones are too expensive for my budget. I found a MAC AW434 at a good price and bought it. I don't know much about air powered impact wrenches but I have used them before. I am confident that I can take it apart clean it and re-grease the hammer components. I also understand about putting good air tool oil into the air intake before and after using the tool. I can not find online anywhere an owner/user manual for the AW434 so I have a question about it that I hope that you can answer for me. There is a plug on the tool right next to the air inlet that takes an Allen key to remove. It is right inline with the grip and the trigger. I found a schematic of the tool and under the plug is a part called the OILER FELT. I want to know if I need to put oil into the tool through this opening since the name OILER FELT implies oil. I think that I understand everything else about the tool but any advice is appreciated. If you have any idea where I can find a manual please let me know.
Thank You
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
205196 (A52706)
205196 (A52706)
2015 Ford F-550 Enclosed Service Truck w/ Liftgate (A59230)
2015 Ford F-550...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A59823)
1987 CATERPILLAR...
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
