Cliff_Johns
Elite Member
I've put about twelve hours on my Mackissic chipper/shredder which I bought used on Ebay a couple months ago.
It's rated for 3&1/2 inch and I think will work with 12 PTO Hp or more.
I run it behind my JD4110 and it does not appear to have any affect on the motor even when feeding 3&1/2" branches at speed. It does use a belt and it will slip if you jam something. I've smelled the belt slipping a couple times.
Very solidly built, easy to run.
Chips to a nice size for mulch with the standard screen, but can produce smaller or larger chips if you buy another screen, but the standard one is perfect for me.
I would not consider a chipper without a shredder now that I have used one that has a shredder. Note that the chipper feeds the chips into the shredder so the chips come out a fairly uniform size.
The shredder will suck brush in so fast, it can strip your fingers if you're not wearing stout gloves. Up to an inch or so, you just toss it in the shredder hopper.
The Shredder had a broken hammer when I got it. I can't imagine how the previous owner broke it since it's a thick piece of steel, but when I called the company and explained that one broke, they just sent me two replacements without any questions. I talked directly to the maintence manager who was very helpful and quite friendly. It felt like a family business. I didn't have a manual either and they sent me one of those too, again without any question. I would say their service is top rate.
It dumps the chips on the ground below the chipper, which can be annoying when you have to scoup the chips away once in a while. On the plus side, when I feed some rotten stuff in the turns to mostly powder, it doesn't get blown in the air nearly as much.
The chipper is not self feed, which I don't view as a problem especially given the price and safty difference for a feed system, but when a branch gets maybe 10" long and you have to let go, it tends to bounce around in the hopper until you feed the next one in. I glued up a push stick (3&1/2" square end and a handle) to push the last bit in. Just my preference, I suppose you don't really need that.
The chipper sells for $1,399 at Northern. I think it's a very good price for the quality and support of the product. It is a really robust and well designed machine.
Cliff
Cliff
