magnetic block heater
   / magnetic block heater #1
warcloud
Thought about using a magnetic oil pan heater for my BX 2360 instead of installing a block heater. Anyone ever used one? Is it safe to do or should I just put in a block heater.
   / magnetic block heater #2
warcloud, where have you seen them? If you didn't have a built in block heater and they are even half good may be nice to have if it gets REALLY cold.
   / magnetic block heater #3
I have used a couple different ones. Don't waste your money. For as easy as you can get and install a real block heater, I woudn't bother.
They barely accomplish anything.
   / magnetic block heater #4
Don't waste your $..the block heaters are more efficient and easy to install..
   / magnetic block heater #5
I've got 2 of the magnetics....................... now I also have a inline block heater. Don't waste your time, get the inline.{SMO}
   / magnetic block heater #6
A magnetic heater is better than nothing but, only a little. The block heaters work really well, plug it in for an hour and it is warm, two hours and you would think it had just been running.
   / magnetic block heater #7
I dont know how they work,but a screw in block heater is simple to install,we can help you with ithere on TBN
alan
   / magnetic block heater #8
alan
The in-the-block heater and the magnetic heater both put out the same amount of heat and both use the same amount of electricity. The installed type screws into the water jacket part of the engine block and heats the water - which heats the block. The magnetic kind is the same heater with a magnet built on the side so it can be stuck to a convenient place on the motor block. Obviously the magnetic type isn't going to conduct as well to the motor block plus it is going to lose some heat to the surrounding air. Lots better than nothing, but not nearly as good as a heater threaded right into the engine.
   / magnetic block heater #9
At what temperature do you begin to consider installing a block heater? Most of our winters are spent in the 30's (F) with an occasional dip down to 0 at night.
   / magnetic block heater #10
There is probably some reduction in engine wear by pre-heating even in the summer. Same goes for transmission heaters. At any temperature below 40F my diesel tractors sure start easier when heated. Below about 20, heating is necessary for them to start at all.
The only one without a heater is the old 1958 JD530 gasoline tractor. It will start from cold at 20 below with nothing but a little choke.
rScotty
Wooden Dining Table (A55853)
Wooden Dining...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
Kawasaki Mule 2510 4x4 Utility Vehicle (A55851)
Kawasaki Mule 2510...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
Peterbilt (A51692)
Peterbilt (A51692)
