Mahindra 3505 hydraulic fluid fill spot
   / Mahindra 3505 hydraulic fluid fill spot #1
@ the funny farm
Mahindra 3505
I’m replacing a bad pto seal and decided to drain the hydraulic trans fluid . Pulled three plugs on the bottom only got about 5 gallons out should be closer to 10 . Next problem where to fill ? There is a plug behind the seat but dealership seems to think it’s on the transmission ?
   / Mahindra 3505 hydraulic fluid fill spot #2
What is this? Right side of seat sq head plug.
I have a 3505 Mahindra and that’s where I check the hydraulic fluid - trans fluid level. If you unscrew it, there should be a dipstick in there.
But I’m not sure if that’s where you fill the hydraulic/transmission fluid. That’s what I’m trying to figure out.
IRanch High-End Mini Golf Cart (A57149)
IRanch High-End...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
2010 GLOBAL TRI AXLE HAUL TRAILER (A58216)
2010 GLOBAL TRI...
2009 INTERNATIONAL DURASTAR 4300 SBA ROAD TRACTOR (A58375)
2009 INTERNATIONAL...
207279 (A52708)
207279 (A52708)
