Mahindra 3505 hydraulic fluid fill spot
   / Mahindra 3505 hydraulic fluid fill spot #1
@ the funny farm
Mahindra 3505
I’m replacing a bad pto seal and decided to drain the hydraulic trans fluid . Pulled three plugs on the bottom only got about 5 gallons out should be closer to 10 . Next problem where to fill ? There is a plug behind the seat but dealership seems to think it’s on the transmission ?
   / Mahindra 3505 hydraulic fluid fill spot #2
What is this? Right side of seat sq head plug.
I have a 3505 Mahindra and that’s where I check the hydraulic fluid - trans fluid level. If you unscrew it, there should be a dipstick in there.
But I’m not sure if that’s where you fill the hydraulic/transmission fluid. That’s what I’m trying to figure out.
40' High Cube Multi-Door Container (A53314)
40' High Cube...
1999 CHEVROLET C7500 UTILITY TRUCK (A56129)
1999 CHEVROLET...
StihlWeed Eater (A47477)
StihlWeed Eater...
2016 Nissan Frontier Ext. Cab Pick-up (A53422)
2016 Nissan...
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
CASE CX330 EXCAVATOR (A52707)
CASE CX330...
