Mahindra 3616 blower broken shafts
   / Mahindra 3616 blower broken shafts #11
For this specific failure mode, it's maybe a bit of a stretch, but are you setting the augers up out of phase with each other? I've never had a Berco customer chewing up gearboxes with any regularity, but incorrectly positioned augers can beat things up fast.
1:p24 } DECAL AUGER POSITIONING - Salem Power Equipment, LLC
Brian
   / Mahindra 3616 blower broken shafts #12
I know this was 2 years ago. But did you ever figure out why your input shaft was breaking? Mine, 66" on a 3016, just broke.
I forgot all about this post, yep bhildret I make sure the augers are in phase, and strathhamboat no I never have, I just broke #5 this winter.
   / Mahindra 3616 blower broken shafts #14
Thanks for the contact.
Input shaft breakage is relatively rare and the items previously mentioned in this post all apply. This specific post is the only case I am aware of with repetitive input shaft failures.
Key items of consideration: 1) properly phased left and right augers, 2) correct OEM shear bolts in the auger and fan, 3) check auger shafts for bent/bowing, which can cause excess loads on the input shaft/gear box (that's pretty rare).
We would be happy to help with necessary repair parts.
Brian
www salempwr com
   / Mahindra 3616 blower broken shafts #15
I have the smaller blower for the Max26xlt. Gear box went out after about 5 hrs of use and this is a new unit. I haven't repaired it yet to find out what broke. Have been seeing augers offset per decal and using proper grade shear pins. I wish it was a chain driven auger instead of having a WEAKNESS gear box.
   / Mahindra 3616 blower broken shafts #16
Meant weak gearbox
   / Mahindra 3616 blower broken shafts #17
There may be a belt at the blower end of the drive shaft that is broken.
   / Mahindra 3616 blower broken shafts #18
Meant weak gearbox
Finally got around to working on the Bercomac 56" snowblower. Turns out that the propeller shaft broke just inside the gear box at the point where the shaft is machined down. This may create a weak point in the shaft. Not happy. This is an expensive blower with only a total of 4 hours of use. Plus takes alot of time repairing.
   / Mahindra 3616 blower broken shafts #19
Sorry to hear the shaft is broken....
   / Mahindra 3616 blower broken shafts #20
Are you blowing any rocks like on a gravel driveway or do you drive fast in wet snow and catch ice?
2016 Ford Explorer...
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
Simpson 3100 PSI Gas Pressure Washer (A51573)
Simpson 3100 PSI...
