Mahindra 4510 temperature gauge location
   / Mahindra 4510 temperature gauge location #1
yanmars
Veteran Member
I had my tractor worked on about an hour away. When I used it, it appears the temperature gauge was not hooked up. I do not want to reload it, an hour each way. I found two disconnected male connections but no female connections. Also two plastic covered coil springs that seem to go nowhere.
Any thoughts on this or where I need to look to make the connections.
I really need to have the temp gauge working because in weeds it clogs up and wants to get warm. As soon as I see that I can clean it and keep it under control but I do not want to be checking every five minutes either without the gauge. Thanks
2003 MACK 1M2 DUMP TRUCK (A60430)
2003 MACK 1M2 DUMP...
2021 CATERPILLAR D5 LGP HIGH TRACK DOZER (A60429)
2021 CATERPILLAR...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
HYD BREAKER HAMMER (A60429)
HYD BREAKER HAMMER...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
2016 Volvo Semi (A59814)
2016 Volvo Semi...
