Oil & Fuel Mahindra 4530 hydraulic fill location
   / Mahindra 4530 hydraulic fill location #1
gmanksu
I have a 4530 used and manual did not come with it. Is the hydraulic check/fill location the 1/2 nut we with about 5" dipstick (looks more like a screwdriver shank) to the front of the left side step? The nut on my tractor is painted yellow but not otherwise labeled. Second question is how much fluid is the capacity, so I don't overfill.
I have read that thread it never specifically said where the 4530 hydraulic fill port was!
   / Mahindra 4530 hydraulic fill location #4
The hydraulic fill and dipstick is commonly a nut with a small stick attached. It’s hard to overfill. It should be something like 10 gallons and with a flashlight you should be able to see in that hole. Even filling 1/2 gallon at a time will get you their without overfilling. The hydraulic fluid is a big reservoir- it can fluctuate a lot and be just fine.
   / Mahindra 4530 hydraulic fill location #6
The fill is right behind your seat and the dip stick to check it is sort of below your left foot.
Jumper Cables (A57149)
2150 (A58376)
2150 (A58376)
New/Unused AGT Industrial 70-inch Seeder (A57454)
New/Unused AGT...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
2016 Chevrolet Cruze Limited Sedan (A56859)
2016 Chevrolet...
