Oil & Fuel Mahindra 4530 hydraulic fill location
   / Mahindra 4530 hydraulic fill location #1
gmanksu
I have a 4530 used and manual did not come with it. Is the hydraulic check/fill location the 1/2 nut we with about 5" dipstick (looks more like a screwdriver shank) to the front of the left side step? The nut on my tractor is painted yellow but not otherwise labeled. Second question is how much fluid is the capacity, so I don't overfill.
I have read that thread it never specifically said where the 4530 hydraulic fill port was!
   / Mahindra 4530 hydraulic fill location #4
The hydraulic fill and dipstick is commonly a nut with a small stick attached. It’s hard to overfill. It should be something like 10 gallons and with a flashlight you should be able to see in that hole. Even filling 1/2 gallon at a time will get you their without overfilling. The hydraulic fluid is a big reservoir- it can fluctuate a lot and be just fine.
   / Mahindra 4530 hydraulic fill location #6
The fill is right behind your seat and the dip stick to check it is sort of below your left foot.
2212 (A58376)
2212 (A58376)
HPS MS-017 2 Phase Generator (A57148)
HPS MS-017 2 Phase...
CABINET OF HOSE ENDS (A58214)
CABINET OF HOSE...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
2022 Chevrolet 1500 Silverado Crew Cab 4X4 Pick-Up Truck (A56858)
2022 Chevrolet...
SKID STEER ATTACHMENT PACKER (A58216)
SKID STEER...
