Mahindra 4530 Stalled
/ Mahindra 4530 Stalled #1
Blaze08
Ga
Mahindra 4530/Ford 4610
First off, hello I'm new here. (Obviously)
Problem 1...my 06 4530, the ignition switch hasn't worked for quite sometime so I have to jump over the solenoid with a screwdriver every time to crank it.
Problem 2...yesterday while driving out to feed my cows the tractor stalled and died. Once it did that, it hasn't started back since. I was told it was maybe clogged fuel filters, changed those today...nothing. It will not turn over, basically it's the same sound whether the key is in the on position or off.
Any help is appreciated, thanks!
/ Mahindra 4530 Stalled #2
Sounds like the switch finely craped out. Not sending power anywhere. :confused3:
/ Mahindra 4530 Stalled #3
You have a safety switch on the pto and the low/high shifter.. im sure one was engage or they can get stuck and not work properly.. usually the pto. sounds like it popped your starter relay or one of the fuses. check your fuse box. This is an electrical issue and no other
Is the safety switch on the pto the "beeper" button? Or is it somewhere else?
And I will add the 30 amp starter fuse was blown, but I replaced that and nothing changed.
/ Mahindra 4530 Stalled #5
No that's just for the beeper that's on the pto clutch not the pto engage.. the switch is on the right lever.
/ Mahindra 4530 Stalled #6
Are you getting power to your dash when you cut the key on? light lights and what not?
Yes lights/gages are working.
On the right lever, where?
/ Mahindra 4530 Stalled #8
There are two levers for the PTO one is the clutch and one is the engage. there is also the switch on the high/low you will need to take a panel off to get to it.. replace both of them if you want to get going quick.. but you can put a test light to them to figure it out for sure.. it is your problem though I can assure you..
The cover that goes over the starter have you been keeping it off since it you been bump starting it? If so trash probably got on top of the starter and made an arch causing your starter fuse to go...
Ok, I will check that out. I guess I go ahead and order those switches and try that.
Also, should I then be able to crank with the key? Or is that another issue?
/ Mahindra 4530 Stalled #11
Yes after that you should be able to crank with the key no problem. If you ever get on the tractor and you turn the key on... get full lights and everything seems normal then when you turn to crank it does nothing at all.. no noise no bump no nothing.. its a switch... either something is engaged or the switch is stuck. or of course the fuse is bad.. take a lot to pop the fuse though.. if it was low battery or power cord failure or a bad ground, starter, solenoid, etc you would get some type of bump or ticktickticktick.. or obvious loss of power when the key is turned. Good luck you should be up and running in no time
/ Mahindra 4530 Stalled #12
you havnt tried bump starting it since you replaced the fuse right
Yes I did, and it still wouldn't turn over bumping it.
/ Mahindra 4530 Stalled #14
Did it make any noise at all?
actually do you have a multimetor?
/ Mahindra 4530 Stalled #15
It didn't pop the fuse again did it? wonder if the starter relay went with it... its a small white box near the fuse panel
Same,only spinning not turning over noise. Same if key is on or off.
I didn't check the fuse after I changed it and tried it.
/ Mahindra 4530 Stalled #17
Ok you got noise that's good... kinda.. this means your relay is good but your not getting enough power to kick your solenoid out... this can come from the battery not being hot enough or the ground is bad were it leaves the battery and hits the frame... its just bolted to the side of it and can get dirty.. take it off clean it up bolt back on... next is less likely but the connections at the battery and the starter can be bad too.. wouldn't hurt to clean them up also.. lastly your power cord can go bad... a multi meter will tell you how much juice is getting to the starter if you have one. could be a bad solenoid from the bumping but doubt it... all and all with the key not making it spin itself one of the switches are not working on the pto or high/low.. hope you figure it out ill check up tomorrow if I get time
OK, thanks I really appreciate it. It will honestly be Thursday evening probably before I get to try anything.
Ok, so after some time tinkering and cleaning...the key worked..kinda. It still just spins and won't turn over.
The battery was new this fall, could it be losing power and not have enough to turn it over?
And no I don't have a meter.
Or????
/ Mahindra 4530 Stalled #20
You tried to jump it off or charge the battery? Im sure you have plenty of moisture in the air same as here in Tx. it can mess up connections and let a battery draw much quicker than 6 months. Id charge it up or put some cables to it
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2 - WEATHER GUARD TOOLBOXES (A55745)
2 - WEATHER GUARD...
UNUSED SDLANCH SDLC2030FT-20'X30' CARPORT (A60432)
UNUSED SDLANCH...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2021 KOMATSU PC490LCI-11 EXCAVATOR (A60429)
2021 KOMATSU...
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
