mahindra 5010 hydrualic steering problem
   / mahindra 5010 hydrualic steering problem
no it is not in special circumstances . the dealer used a 55 gallon drum of water in the bucket and it did it. The dealer was told about the static steering from Mahindras service rep, which the rep got the information from the Mahindra eng. Dept. the dealer gave me the service rep's number and I called him and he told me the same story the dealer told me so I'm at a lost right now
   / mahindra 5010 hydrualic steering problem #12
Mahindra has essentially coined a new term for inadequate hydraulic steering. The relief valve pressure setting shound be increased to the max. Yours is probably on the low side. On my 7520 the system cannot control the direction of the wheels in a hard push on uneven ground. It is better when cold, like yours. I am considering going to 5W-40 oil but need to check its hi temp viscosity vs the ATF which is standard.
larry
   / mahindra 5010 hydrualic steering problem #13
Spyderlk, I think what you are saying has merit. I think the customers 5010 is not working right. Pressures need tested. And static power-steering? I've not heard of that. I'll say again, the 10 series with the widest tire option has always, going back to the 4110 even from years ago, had a issue when fully loaded and completely stopped and in great traction situations. Most people never notice it. On the OP tractor, it sounds much worse. I would think there is a specification as to how much pressure is applied before bypass, and that needs to be figured out and checked if it hasn't been already. Just my $0.02 worth.
   / mahindra 5010 hydrualic steering problem #14
Just enjoying the sun ... but working my tail off too !
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
1991 INTERNATIONAL WATER TRUCK (A52472)
1991 INTERNATIONAL...
2012 MACK CXU PINNACLE (INOPERABLE) (A52472)
2012 MACK CXU...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
Unused 2025 Spirit Mini Golf Cart (A51694)
Unused 2025 Spirit...
