Mahindra 6000 di PTO problems
   / Mahindra 6000 di PTO problems #1
Rhbigdad
Kingsville
Mahindra 6000 di
it appears that my PTO lever has disconnected from inside the PTO if anybody has any suggestions I would appreciate it. I pulled the cover on the side of the tractor and tried to remove the lever itself but it would not come out all the way but it's not engaging at all feels as if nothing is connected to it
   / Mahindra 6000 di PTO problems #2
Did you ever fix this? Same thing happened to me, you sheared the tapered pin that holds a block on the end of the pto. Fish around with a magnet and find it in the hydraulic tank. The lever should come all the way out, you will need to remove the fender and tire from that side of the tractor.
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A55745)
2015 VANTAGE...
2455 (A60432)
2455 (A60432)
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
296385 (A57192)
296385 (A57192)
2015 CASE SV280 SKID STEER (A60429)
2015 CASE SV280...
