Mahindra EMax 20 S - Hydraulic Oil Fliter Stud Sheared Off
   / Mahindra EMax 20 S - Hydraulic Oil Fliter Stud Sheared Off #1
rwhitwo
2018 Mahindra Emax 20S
So the drive shaft from the belly mower disconnected while mowing and it snapped off the hydraulic oil filter with the threaded stud inside the filter. It appears this stud or "nipple" is machined into the face cover of the transmission. According to the Mahindra Parts Catalog this cover is called "Input Metal" part # 11612310010M. It has a proce but when try to order it says unservicable part and cannot be purchased. Does anyone know where I could get this part. My recourse is to remove the cover and drill out snapped thread post and try and machine in a new nipple. Open to any and all suggestions.
Thanks
Rwhitwo
   / Mahindra EMax 20 S - Hydraulic Oil Fliter Stud Sheared Off #2
Might see if there is a solution in this thread... Yes its a Massey Ferguson thread but seems to ibe dentical issues...
Thanks for this suggestion! It led to a successful outcome.
   / Mahindra EMax 20 S - Hydraulic Oil Fliter Stud Sheared Off #4
I have the same issue now- what did u do to repair. I'm thinking welding it back on- mine has a clean break
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A46683)
2017 Freightliner...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A45676)
2015 FREIGHTLINER...
2019 BIG TEXT LIGHT PLANT/WATER COMBO (A47001)
2019 BIG TEXT...
Schulte FX107 84in Rotary Cutter Attachment (A46683)
Schulte FX107 84in...
2010 Ford Explorer XLT SUV (A46684)
2010 Ford Explorer...
2013 UTILITY 53X102 DRY VAN TRAILER (A45677)
2013 UTILITY...
