Mahindra vs Kioti
   / Mahindra vs Kioti #42
So then give the facts?
Bet you can’t!
Agreed. Kubota is Japanese made by Kubota. Kioti is Korean made by daedong. It doesn’t seem very related.
   / Mahindra vs Kioti #43
I would be curious where the lift capacity for the Kioti is measured from the pin on the bucket and the height the capacity is measured? Also I would be curious where the hydraulic pressure set for the Kioti. I've heard of Kubota owners increasing their hydraulic pressure from 2350 psi to 2550 psi and gaining lifting capacity.
It remains to be seen if the Kioti front axle will withstand the increased lifting capacity if it truly is rated at the same distance as other brands.
I think you are exaggerating by saying "far exceeded". I would have loved to have looked at a Kioti but the nearest dealer was 2 1/2 hrs drive from me.
About the only thing on the CUT Kioti's I see that far exceeds is the seat.
Kioti NX
3PH: 3177lbs at 24"
KL6010 FEL: 2761 at pins full height
FEL RV: 2556
Kubota Grand L5060 despite having 2 gross engine hp more (52) than my NX5010 and 7 gross hp more than the NX4510, has 200 lbs. less 3PH lift, 2 gpm less hydraulic flow, weighs almost 400 lbs. less, and the beefiest loader lifts 400 lbs. less.
I'd say that equates to Kioti far exceeding and at lower cost. Oh, and the seat is awesome too. :laughing:
   / Mahindra vs Kioti #44
Another one looking for facts.
The only connection between Kubota and Kioti, was some legal issues due to the paint color a long time ago.
Then Kioti sold a few models with Kubota engines also a long time ago.
   / Mahindra vs Kioti #45
I am not in need of the facts But think those who want to post without knowing them should go and find them before posting thier bull crap.
   / Mahindra vs Kioti #46
Kioti generally specs lift capacity at full height at the pins (not out from the pins)
Hydraulic PSI and lift height are listed in the specs for each model.
   / Mahindra vs Kioti #48
The FEL comparison that I listed above (#43) is for Kubota at the pins from their web site spec page.
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
2023 Deere 333G (A53317)
2023 Deere 333G...
UNUSED FUTURE LS43 HYD WOOD SPLITTER (A57193)
UNUSED FUTURE LS43...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A57193)
UNUSED FUTURE SKID...
