Main electric service line too long?
   / Main electric service line too long? #31
I ran conduit from the meter to the house and shop (both 150 ft runs) for two reasons. If ever need to replace the wire I can do it without trenching and conduit doesn't need to be buried as deep. For the price of 2 inch PVC it was an easy decision. The funny part is I have direct burial cable in the conduit.
   / Main electric service line too long? #32
</font><font color="blue" class="small">( I guess I am baffled. Why would you use conduit? Around here, code is apparently to use wires suitable for direct burial. I have seen even the high-voltage runs done this way (no conduit, just the wires in a trench). Why are you all putting down conduit? /forums/images/graemlins/confused.gif )</font>
For one, it is our code that schedule 40 be used. Second, we have a gazillion rocks and boulders that constantly work their way upwards from underground, and that is the reason for piping...
   / Main electric service line too long? #33
</font><font color="blue" class="small">( The funny part is I have direct burial cable in the conduit. )</font>
I'm doing the same thing - 2" schedule 40 PVC with 4/0 4/0 2/0 URD.
For me the big advantage will be not having to bury it so deep - I have to cross 1 culvert and a pair of french drain lines, all of which are buried fairly close to the surface.
   / Main electric service line too long? #34
Okay, I need to make sure I understand the 4/0 for the lines and 2/0 for the neutral. I’ve heard that the NEC allows you to use a neutral that is two sizes smaller than the lines. I’m guessing this applies only to main feeds for 240V single phase.
I’ve always run the same size neutral as it stands to reason that you have as much current going through the line as you do through the neutral - for 120V circuits that is. I’m guessing that the reason they let you run a smaller neutral is because the loads are supposed to be fairly balanced load between the two 120V lines. Since they are 180 degrees out of phase, their currents cancel out on the neutral line. The 220V circuits don’t even use the neutral.
Is this right or is there another reason?
   / Main electric service line too long? #35
I agree the nutral doesn't need to be any larger than the feed lines. The nutral only sees(carries) one phase at any given time.
   / Main electric service line too long? #36
Gary,
I can't comment on your questions regarding the reduced neutral - it sounds good to me - but then I'm not an electrician and have limited knowledge in the area .... where's Inspector507 when you need him .... ? /forums/images/graemlins/grin.gif
I'm just operating off what I was told would work for my particular situation.
   / Main electric service line too long? #37
correct. some balance between the two legs is assumed thus allowing for a reduced neutral. If you have a situation where you know this not true then a larger neutral is needed. Very unlikely in a residential type situation.
2014 Freightliner 105' Bucket Truck (A56436)
2014 Freightliner...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2019 PJ TRAILER 32FT GOOSENECK (A55745)
2019 PJ TRAILER...
Honda UTV (A56859)
Honda UTV (A56859)
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A56438)
2016 KBH...
JLG 1255 Telehandler (A56436)
JLG 1255...
