Making sense of hydraulic fittings
   / Making sense of hydraulic fittings #11
Wayne County Hose said:
. Go back and edit that last one where ya got so happy and see if when you save it, it has the box around the quote. It's more readable that way. Add
right before the Wooooo-Hooooooooooooo ;)
When you hit the quote button it will add
Oh Curly, you took the wind right out of my sails. Let's see if this works. By the way, I am holding my hand vertically in front of my nose so you can't poke me in both eyes at once.[/QUOTE]
   / Making sense of hydraulic fittings #12
[/QUOTE]
I'm so flippin' confused right now. I'm going to go smash my hand with a hammer so my head quits hurting.
   / Making sense of hydraulic fittings #13
That sounds like a good 3 stooges kinda thing to do.
I think I may have screwed you up a bit because I put all of those words (I'm not gonna put them here or it'll screw you up again) in there exactly the way it will be looking for them. So try quoting this one and see how it works:D
Yeah, I definately screwed you up. I did a quote on that same post of mine that you did...and it was all messed up. So that was definately not a good one to practice on.:rolleyes:
   / Making sense of hydraulic fittings #14
:rolleyes
Woooooooop-woooooop-woooop-wooop. Nyaaaaa, how's that Curly.
   / Making sense of hydraulic fittings #15
I ain't curly, but I do have curly hair, and it looks good from this end of the world.
David from jax
   / Making sense of hydraulic fittings #16
David from jax
Hair...what's that?:D
Yeah Wayne...ya got it.:)
   / Making sense of hydraulic fittings #17
I just bought a couple of cylinders from suplus center. The ports only listed as SAE 6 and 8 on the other. Is this the same as JIC or are these SAE ORB?
   / Making sense of hydraulic fittings #18
Wayne you know your stuff. I know what I am doing ,usually, but it seems I always pick up something from your posts. Thanks
   / Making sense of hydraulic fittings #19
They are SAE O-ring I believe, Not JIC. You will need adapters.
I think SAE ORB is "O Ring Boss"
This might help:
North American Coupling Types
BTW - Great explanation from Wayne County Hose, I liked it.
   / Making sense of hydraulic fittings #20
JIC and straight thread o-ring are the same thread. Difference is an o-ring at the base. For the sake of simplicity, you will want straight thread o-ring to JIC adaptor. I don't know why they list these cylinders as having SAE fittings when they are straight thread o-ring. I guess different manufacturers sometimes use different terminology. SAE is 45 degree flare, similar to the 37 degree JIC flare.
In a pinch, you could put an o-ring on a JIC male and use it as a straight thread o-ring fitting. Make sure you use the correct o-ring on your fittings, not one from a generic kit. There is a difference. You can get the proper o-ring kits from Hercules Sealing Products for far less money than you think.
I hope this helps rather than confuses. Sometimes I throw info out there without thinking how it gets interpreted.
yellow ball Trailer (A56859)
yellow ball...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
Sedan (A59231)
Sedan (A59231)
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
