Manual Hydraulic jacks to powered.
   / Manual Hydraulic jacks to powered. #11
You can use a single way cylinder on a tractor. They were used for many years on loaders. All you have to do is look up to one quick disconnect
I was referring to the post of making a top link and I stick to my original statement that it won’t work. I should have quoted but I didn’t see the post in between or we posted at the same time.
   / Manual Hydraulic jacks to powered. #12
I think most jacks, like hydraulic presses, with their own hand pump are operating at much higher pressures than any tractor's hydraulic system. Around 10,000 psi
Check that fact before doing a lot of work and then finding you have a limp link.
Dave M7040
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
Kubota L4701 (A53317)
Dodge Charger (A56859)
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
