Manual vs Hydro Transmissions
Status
Not open for further replies.
   / Manual vs Hydro Transmissions #101
Mornin Red,
Ahhh, now youve gone and done it !!! Actual photogenic proof that 2 WD tractors actually can hold their own in the work department ;) :) :D
   / Manual vs Hydro Transmissions #102
Great pix. But does it have an AM radio and a 4 track stereo?
A good workman can do wonders with even a primitive tool.
Pat ;)
   / Manual vs Hydro Transmissions #103
Pat ;)
iPod. You didn't notice the earbuds? By the way, I'm the distinguished looking portly gentleman with the white beard.
   / Manual vs Hydro Transmissions #104
My appologies, I thought it was your dad.
Pat
   / Manual vs Hydro Transmissions #105
Pat ;)
Pat, Pat, Pat,
What are we going to do with you? A "4 Track" was the original endless tape system for music. There were 4 separate sets of recordings put down in parallel on the tape, 1 at the top edge, 2,3 in the middle and 4 at the bottom edge. The music was in MONO. When it went to stereo, it had to split each of the tracks for L and R speaker playback. That doubled the effective number of tracks and it became an 8 Track STEREO.
jb
   / Manual vs Hydro Transmissions #106
john_bud said:
Pat, Pat, Pat,
jb
Send money, lots of money, so I can hire a trivia tutor!
Are you positive that Lear didn't do any stereo in the 4 track format prior to commercialization of the 8 track?
Pat
   / Manual vs Hydro Transmissions #107
Pat
"checks in the mail"
I don't know if they did or didn't. Can't recall any - but that means little! If they did, it was quickly tossed aside like dirty socks when the 8 tracks came out.
jb
   / Manual vs Hydro Transmissions #108
jb
Bought one four track in my life. Hermans Hermits. I completely skipped over the 8 tracks, left that up to my friends. I was the first with a stereo cassette tape and for sure had the very first CD player. I was told that the CD would never make it, it was just a fad, they will never replace vinyl. Well, they did for the masses but on the otherhand, the life of CD's may well be coming to an end as well. I still have my old Beta machine, its a tank, runs great, kind of like the old geared 2WD tractors out there. (I had to throw that in to stay on topic)
   / Manual vs Hydro Transmissions #109
Before you run off and chastise me.. go back and reread my message.. very slowly. The 3 of you missed my point entirely.
What I specifically said was that you either had to hold your foot on the pedal or use cruise. if using cruise, then you have to 'make an action' to get it off cruse.. I.e. brake or hst pedal. my point was that it also only takes a single action to dump an hand throttle on a geared unit.. Thus.. not much gained in the 'ease' dept. when looking at long runs with a throttle set and same ground speed.. say like mowing... In other words.. i don't see much valvue in hst over gear for flat open pasture mowing..
If I remember correctly, the argument was that it took to much 'playing' with l;evers and such on the geared tractor to do anything. my point, is that for some operastions.. it takes pretty much 'equal' time to go thru the motions for either transmission.
Obviously this is application specific. Some apps will heavilly favor a specific tranny.. so will be neutral. I see mowing as neutral in most cases.. or if in close quarters with lots of obstacles, then it leaning back over tot he hst.. Loader work obviuosly would like an HST.. or at least an advanced gear, like a shuttle.
I know you guys just like to look at a couple sentences and then shoot a reply off.. but it really does pay to read all the typed words...
Soundguy
patrick_g said:
SoundGuy, Try as I might I just can't undedrstand why you make a statement about holding your foot in a single position for hours. I have never done or thought I would need to do that. Even if you did, the ergonomic design of the Kubota HST pedal would make it pretty easy but it sure isn't required.
Cruise automatically turns off if you tap the brake or move the HST pedal. Cruise really does work neat. If for some reason you didn't want to "disturb" the cruise setting and only needed to slow down but not completely stop, you could ****** the throttle and the clutch is available if you want to completely stop without changing the cruise setting. Normally I only use the clutch for starting (lock out switch) and for engaging and disengaging the PTO.
The only time I ever held my foot on the pedal for very long in one position was all the way forward which is not particularly tiring as you can hold it with a toe, heel, left or right edge or whatever, not a cramping sort of thing. No more tiring than just having your foot resting on the floor.
Of course, with experience a good operator such as yourself and many others here learn to optimize their performance within their tractor's capability. Irrespective of what equipment you have, as you indicate the operator is an important part of the mix. Not everyone is cut out to operate equipment and there are no current designs on the market that can make everyone a good operator. I suggest the HST comes closest.
Pat
   / Manual vs Hydro Transmissions #110
Pat.. here is the sentence that I quoted from your message:
:If speed is importanty in initiating a stop then you can't beat my : Kubota :HST. Most folks don't drive much of the time with a hand on the throttle or a foot on the brake. With my HST as soon as you let up on the HST pedal, where your foot is much of the time, the tractor slows very quickly.
I don't mow with my hand on the hand throttle.. I set it and then leave it alone. Much inthe same way cruise is set then left alone. when you want to void the cruise ( and thus drastically slow down.. as your sentence implies, when the hst pedal comes up ), then you have to make a single movement to void the cruise. My point was that in order for me to slow down on a gear unit.. i also only have to make a single movement.. that is.. dumping the hand throttle.
Now.. if the argument was that you mowed with your foot on the hst, and just let up to slow.. then the same could be said of a foot throttle on a gear.. again.. a single movement.
that was my entire point. For some applications.. there just isn't much practical benefit of an hst tranny over a geared unit... etc.
Clear now?
Soundguy
Status
2014 Ag Spray Schaben Sidedresser (A55302)
2014 Ag Spray...
2018 PETERBILT 579 DAY CAB (A56129)
2018 PETERBILT 579...
2005 Mack CV713 Granite 18 Yard Quad-Axle Dump Truck (A55788)
2005 Mack CV713...
Mini Excavator Bucket (A53316)
Mini Excavator...
7091 (A47477)
7091 (A47477)
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
