Manual vs Hydro Transmissions
Status
Not open for further replies.
   / Manual vs Hydro Transmissions #71
Set and forget geared tranny vs the FOOL_WITH_THE_PEDAL_ALL_THE_TIME HST...
My HST has a hold mechanism (poor man's cruise control) that locks the HST postition wherever you want it until you press the brake or the HST pedal and then it releases automatically and if the brake was what caused it to disengage then the tractor stops pronto whether or not you continue to apply the brake.
I fail to see how a geared tranny is superior to that. It seems to me the automatic stop when the HST-"HOLD" is disengaged is a safety feature beyond the geared tranny.
Pat
   / Manual vs Hydro Transmissions #72
Soundguy said:
Hmm.. how many 'levers and pedals' do you think a gear tractor has compaired to your car / truck? You think there might be 2-3 clutches 5 gear shift levers??.. Aside from a range selector.. which you would probably be leaving in low for close up work.. I'm guessing that leaves you with an accelerator .. a brake.. a gear shift, and a clutch... Sounds ominously similar to your manual car / truck... (grin)
Glad you l ike your HST.
Soundguy
The big difference between the tractor and my road vehicles is that the road vehicles are used daily and I avoid reverse unless absolutely necessary. I'm one of those people who park far enough out in the lot that I can leave a parking space by going forward instead of using reverse. Now my tractor has about 420 hours over 5-1/2 years of ownership, so it doesn't get the daily use. I like being able to hop on Bambi and go without regaining the hand-eye coordination because of the infrequent use.
The only time I use the brakes is when I'm setting the parking brake, or if I use the individual wheel brakes to cut a tighter turn, or if I'm building a berm and have a load in the bucket that I'm dumping and I don't want to roll backwards. Otherwise, I like the ability to slow down and come to a stop by just letting up on the pedals.
Now with my road vehicles I like the manual as I feel I have superior control of the car or truck that I don't get with an automatic; especially engine braking control descending steep hills. Automatics drive me nuts in that they always seem to gather speed because engine braking isn't as efficient on an automatic.
The only time I use the cruise control on Bambi is when I'm driving to a neighbor's house; otherwise I find it pretty worthless for most chores on my particular lot. As for cruise control on my cars...I never use it, and I have no idea if they even work on my 11-1/2 year old Accord and 8 year old F-250. I tried cruise control on a rental car one time and I didn't like it.
   / Manual vs Hydro Transmissions #73
Hmm.. I'm not sure I'd -always- want rapid deceleration when tapping a brake. I sometimes.. well.. many times like to use the brakes to help steering. I'm not sure I'd like to fumble with a foot pedal, a brake pedal, and then try to keep the cruise engaged.
Perhaps the other user was refering to a gear setup with a hand and foot throttle.. where you like to.. say.. mow at a set speed. You select your range and gear, and then throttle to pto rpm.. and you are at that set speed. As long as you always use that rpm, and gear combination.. you are always back to that set speed. With a hand throttle set.. yo are free to use steering brakes. If ya need to emergency stop.. the fastest way to do it is by dumping the throttle while in gear and under load.. brakes help too.. but not as much as dumping the throttle. I think that is what the other poster was getting at.
Soundguy
Pat
   / Manual vs Hydro Transmissions #74
Hmm.. sounds strangly familiar to how I use my geared tractors. 'Bout the only time I use the brakes is for turning.. or if I'm roading her and come to a stop light / sign, and I still use the throttle to slow down.. but use the brakes to provide a complete stop, if there's traffic.. or a uh.. california roll if none, to save some wear on the clutch... If I'm in the pasture i use the throttle to slow down, and then clutch... she pretty much stops at that point.. no brakes needed.
Soundguy
   / Manual vs Hydro Transmissions #75
Soundguy
Hmmm, I have yet to experience that, perhaps your brakes are shot. My brakes will lock up all four tires.
   / Manual vs Hydro Transmissions #76
I have both. A 2N standard, and a MF-1020 HST. They are both about 20 HP. The 2N will outpull and out power the MF, but if you come to my house your going to find me on the MF. If your going to use it around the house go HST. If your going to farm, go gears.
   / Manual vs Hydro Transmissions #77
My NH TN70A is a "combo" unit with hand and foot throttle. It is all I have ever used, except for HST. The foot throttle is great for everything except set and forget, like bush hog and plowing.
Bob
   / Manual vs Hydro Transmissions #78
I'm not fond of locking up tires, breaking traction and sliding.. chews up the grass something awfull.. plus if on a hard surface.. you now have less control when sliding.
Dumping the throttle pulls you down fast, and the wheels are still turning to help prevent breaking traction. If I need extra stopping power, right as the engine pulls it down, I clutch then break at the point twher ethe forward speed is about to match dumped engine speed.
It makes a diffference when you have 10-12 thousand pounds moving.. I deffinately don't want to slide and break traction!!!
( My brakes are fine... perhaps you are only thinking of a certain size tractor.. and not taking into account larger tractors... )
Soundguy
   / Manual vs Hydro Transmissions #79
I guess I don't understand the deal with the brakes, but as far as compact tractors go I have only owned two and they were Masseys. I can and have parked them both on unreal steep places without any concern about the brakes holding or not. They always hold. It looks like there are many compacts out there from the way posters talk, that don't have brakes worth calling brakes. If this isn't right I am sure some one will speak up.
   / Manual vs Hydro Transmissions #80
Afternoon Jerry,
My twenty year old Massey 1040 still has the original brakes. They work like a champ. Probablly because I hardly ever use them.
Im in Soundguys camp, when he states that if he needs to stop, he dumps the throttle. I do the same thing especially when I am mowing and never worry about sliding on a steep bank that may be slick caused by wetness. It surely beats sliding IMHO. At times I do use the parking brake, and as extra insurance on hills I lower the FEL. I guess the original ownwer must have done the same thing because there seems to be little wear on those brakes !
Status
2016 Chevrolet Traverse LS SUV (A53117)
2016 Chevrolet...
2012 Chevrolet Colorado Ext. Cab Pickup Truck (A55852)
2012 Chevrolet...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
2016 Club Car Carryall 710 Electric Utility Cart (A55853)
2016 Club Car...
2016 Ford F-450 12ft Flatbed Truck (A55852)
2016 Ford F-450...
1998 MACK CH613 DAYCAB WINCH TRUCK (A55745)
1998 MACK CH613...
